I am working on a proof of concept using the RAK7243 Gateway. I have the gateway and sensor communicating correctly using ABP and I can see data being received via the websocket API. I am using the gateway without internet connection and would like to store the timestamped data on a USB drive that plugs right into the gateway. A few of the issues I am having…
The gateway doesn’t have a clock built in, so every time it is turned off the time starts right back off from where it was stopped. Usually the clock would update via internet connection but this is not an option for me. How can I sync the gateways time using the GPS included in the gateway kit?
Is the sensor data stored locally somewhere on the gateway before it is published to the websocket? Where can I find the command to see the data packets as they are sent to the gateway. If I can find where the data is received, it shouldn’t be that hard to redirect it to either a USB drive.
Thanks for the help.
