Extremely annoying issue with one of my rak nodes (19007/4630). BLE is SUPER short-range. Like, across the room has no reception. My hand in front of the antenna blocks signal. When in range, within a foot or two, it works fine, at full speed.
Things I’ve tried:
Another BLE antenna. No change.
NO BLE antenna, thinking the connector may be damaged. Causes there to be absolutely no reception even at super close range - indicates there’s an actual connection to the antenna.
Full firmware erase and reflash. No change.
Remove all hardware modules. No change.
Reseat 4630 core module. No change.
Maybe there’s a damaged or bad cap or resistor somewhere? or was pulled off at some point? or a random blob of solder?
Bluetooth TX power is set by the Meshtastic firmware. You have to ask the Meshtastic guys how to change it. Maybe there is a setting in the Meshtastic App, but I hoenstly don’t know.
