Things network not seeing gateway from 5146
Probably missing something simple but Im having a heck of a time trying to get things network to see gateway from 5146 concentrator on pihat with rpi4b. I have tried so many permutations at this point but my basic set up has been to use rakpios and set up the gateway through the cli. Im in US so my basic parms have been to set nam1 and As_915…1 though i have tried all frequencies. The service starts, i can get out to the internet from the rpi. I have installed latest updates on rpi. The problem is on the things network console. Using the correct eui and tried using all us frequency plans but never got past “Disconnected” I feel like i have done everything properly.
I also tried using the 5146 firmware with the rpi as well and went through the gateway-config. edited conf file as well.
any help would be appreciated. Thank you in advance
What distance between your node and the gateway?
There is no node yet, I’m just trying to get the gateway to show up on the things network side as connected.
What do you use for the gateways backbone, cellular, ISP…?
Some block port certain ports.
The frequency band can be set to any thing.
Say you register a gateway on EU you can set it AUS bands. The region have no relevance to the frequency band
