Issue: A couple of weeks ago I was trying to connect my RAK7244 to TTN but I still can’t do it, I am connected to the internet but my status in TTN appears disconnected.
Setup:RAK7244 915MHZ
Server: us-west
Server: us-west
There is an issue with the web console that makes the last connected data very unreliable. Do you see traffic? Can you send an uplink via the gateway?
Look under the traffic tab.
Find a device/node/mote and transmit?
Best find a device to create some traffic then
Can you see what the logs / journalctl says?
I’d reflash the SD card!
was the first thing that I tried when it did not connect to ttn :C
In that case, you’ll find that there is no DNS setup in the current image!
what do you mean ? how can i solve it?
this is my configuration
Did you setup the static IP & gateway? Will that work On your network?
At the Pi cmd line, can you try nslookup router.us.thethings.network to see if it will resolve.
no he cambiado la configuración solo añadí el servidor DNS en la ultima linea.
intento el comando pero el cmd no lo reconocé
OK, try
> ping router.us.thethings.network
no ping
Can you ping any other addresses?
Dear DylanSaenz,
How do you connect to the Internet, if it’s just wired, it’s not possible, because as you can see. DHCP has been fixed, so you need to modify it!
Best regards!
