matt303
(Matthew)
May 12, 2025, 1:48am
1
I requested JLCPCB to source some TXGA connectors for my custom carrier PCB and they have come back saying they can no longer source them from the manufacture.
I see talks about using panasonic, but they are also not in stock and 5x the price.
Will you be changing the connector type in the near future as the TXGA no longer become available?
beegee
(Bernd Giesecke)
May 12, 2025, 3:14am
2
Welcome to the forum @matt303
There are two alternatives:
1.Pansonic,AXE6***series.
https://industry.panasonic.eu/productfinder?search=AXE6&op=Find+your+product&mode=SEARCH_MODE&rangeAttributeFilters=[]&sort=
2.BOX04008****series.
We are using BOX04008 at the moment, but I am not sure if they are available outside of China.
matt303
(Matthew)
May 12, 2025, 3:35am
3
Hi @beegee I have sent them an email, hopefully they can supply JLCPCB or get JLCPCB to source directly from RAK
I also came across these that look close…
YXT-BB10-24S-02 from YXT - Board-to-Board and Backplane Connector is available for JLCPCB assembly, check the stock, pricing and datasheet, and let JLCPCB helps you assemble the part YXT-BB10-24S-02 for free.
and
YXT-BB10-24P-02 from YXT - Board-to-Board and Backplane Connector is available for JLCPCB assembly, check the stock, pricing and datasheet, and let JLCPCB helps you assemble the part YXT-BB10-24P-02 for free.
But I think they won’t work taking close look at datasheets
Glenn
(Glenn)
January 28, 2026, 12:40am
4
I’m thinking these are the part numbers based on datasheet link from @beegee . Please confirm if you’ve used them. All seem to be in stock at JLCPCB.
AXE540127 40Pin Female Socket
AXE640124 40 Pin Male Header
AXE524127 24 Pin Female Socket
AXE624124 24 Pin Male Header
beegee
(Bernd Giesecke)
January 28, 2026, 3:54am
5
As I said before, we are using these two suppliers for the connectors, which are compatible:
