hello to all ,
i have a problem with the temperature under zero .
I’m using rak1906 but from zero °C the value go out of range stopping all the reading
some suggest ?
Regard
hello to all ,
Regard
Hello @projectsbminfo
Which BME680 library do you use?
In the beginning our examples were using the ClosedCube library which seems to have a bug with negative temperatures.
We switched the examples to the Adafruit BME680 library and I tested it below 0 degrees and it worked without problems. Our example code is updated.
of course i’m using Closecube
I go to update my sw . ! Thank you so much Beegee , hello from Venice
Hello back from the Philippines, here an image from the test I did with the Adafruit library:
