Unify Enclosure IP67 Environmental Considerations
  • What product do you wish to discuss? RAK4631, RAK3372, RAK11200, RAK11310, RAK11722?
    The Unify Enclosure IP67 150x100x45mm for the RAK19007 Baseboard with the RAK4631 LoRa Module
  • What firmware are you using? (RUI3 or Arduino BSP or other IDE (e.g. STM32CubeIDE)?
    Meshtastic Arduino BSP
  • What firmware version? Can it be obtained with AT+VER=?
    2.6.11.60ec05e
  • Computer OS? (MacOS, Linux, Windows)
    Linux
  • What Computer OS version?
    Fedora 42 on Linux Kernel 6.15.4-200.fc42.x86_64
  • How often does the problem happen?
    N/A
  • How can we replicate the problem?
    N/A
  • Provide source code if custom firmware is used or link to example if RAKwireless example code is used.
This is my first time posting here. I haven’t dealt with outdoor electronics like this before, so I just want to make sure I’m setting everything up properly as to not damage the equipment. I am going to be installing the RAK19007+RAK4631 into this enclosure https://store.rakwireless.com/products/unify-enclosure-ip67-150x100x45mm-with-pre-mounted-m8-5-pin-and-rp-sma-antenna-ip-rated-connectors?index=93&variant=42861623771334. I have already ordered the RAK1901 temperature and humidity sensor module so I can remotely monitor those metrics when I begin using the device as an outdoor node and silica gel packets to prevent too much moisture, but I wanted to see if anyone here has had experience with running a similar configuration. Right now, I’m most worried about heat. Considering the device will charge via the solar panel on the enclosure, I need to have it set up in at least direct sunlight, but because of that, I’m worried about heat damage from the Central Texas sun. I am using the MakerHawk 4000mAh 3.7V 14.8Wh LiPo battery for this project if that tidbit helps.
Thank you
