I’m running the RAK4631 on a RAK19001 base board and just installed the buzzer module. I’m trying to set the pin in meshtastic but I can only input numbers. All the documentation I’m seeing for Slot D is the pin is supposed to be IO5. Not sure what pin needs to be input for the buzzer. Any help is appreciated.
Welcome to the forum @booogs
Meshtastic did not follow our GPIO naming, because they are supporting multiple different hardware.
WisBlock GPIO names to GPIO pin numbers can be found in our Github repo.
* WisBlock Base GPIO definitions
static const uint8_t WB_IO1 = 17; // SLOT_A SLOT_B
static const uint8_t WB_IO2 = 34; // SLOT_A SLOT_B
static const uint8_t WB_IO3 = 21; // SLOT_C
static const uint8_t WB_IO4 = 4; // SLOT_C
static const uint8_t WB_IO5 = 9; // SLOT_D
static const uint8_t WB_IO6 = 10; // SLOT_D
static const uint8_t WB_SW1 = 33; // IO_SLOT
static const uint8_t WB_A0 = 5; // IO_SLOT
static const uint8_t WB_A1 = 31; // IO_SLOT
static const uint8_t WB_I2C1_SDA = 13; // SENSOR_SLOT IO_SLOT
static const uint8_t WB_I2C1_SCL = 14; // SENSOR_SLOT IO_SLOT
static const uint8_t WB_I2C2_SDA = 24; // IO_SLOT
static const uint8_t WB_I2C2_SCL = 25; // IO_SLOT
static const uint8_t WB_SPI_CS = 26; // IO_SLOT
static const uint8_t WB_SPI_CLK = 3; // IO_SLOT
static const uint8_t WB_SPI_MISO = 29; // IO_SLOT
static const uint8_t WB_SPI_MOSI = 30; // IO_SLOT
perfect, this is exactly what i’ve been looking for these past few weeks! i ordered the buzzer a while ago and been researching the pin usage since then. i looked up and down forums, reddit and even the local discord groups and no one had an answer.
