seaton
(Stephen Eaton)
1
After updating the firmware on my gateway to V1.1.0055_Release_r191 I’m now seeing payload data received by the gateway is now including a leading ‘0’
I’m using the built in lora server
e.g. payload data from Dragino LHT-65
r188 payload “CC26098B0183017FFF7FFF”
r191 payload “0CC26098B0183017FFF7FFF”
This of course is throwing out all my processing on the packet data.
Is anyone else seeing this?
velev
(Todor Velev)
2
Can you check Data Encode Type under Integrations ? Base64 or HEX? Change it to Base 64 and check the payload.
seaton
(Stephen Eaton)
3
Is set to HEX, will test on Base64
seaton
(Stephen Eaton)
4
Can confirm payload data is as to be expected using base64 encoding
velev
(Todor Velev)
5
Yup it is a bug. Team will fix it asap.
seaton
(Stephen Eaton)
6
thanks for confirming @velev
velev
(Todor Velev)
7
seaton
(Stephen Eaton)
8
@velev Works a treat, also got the packet logger back
Please thank the dev team for getting it fixed so soon
