RAK4631+1906 , RUI3, AT+VER=RUI_4.1.1_RAK4631
Mac OS, Arduino IDE
Code taken from the SmartFarm example and modified for the use with BSEC.
I am using the BSEC library to send temp, hum, pressure, and IAQ to TTN. I can obtain all the values from the sensor; however, the IAQ value remains at the initial value of 50. When using the basic.ino example for the BSEC library, everything works as expected, however in combination with LoRa the iaq value does not change any more.
type or paste code here
```cpp
* Download RAK1901/RAK1902 library from https://downloads.rakwireless.com/RUI/RUI3/Library/
* Besides, install them into Arduino IDE
#include "bsec.h"
#include <CayenneLPP.h>
#define DEBUG false
// Helper functions declarations
void checkIaqSensorStatus(void);
void errLeds(void);
DynamicJsonDocument jsonBuffer(4096);
CayenneLPP lpp(51);
JsonArray root = jsonBuffer.to<JsonArray>();
void uplink_routine();
#define SMART_FARM_PERIOD (30000)
LoRaWAN band setting:
RAK_REGION_EU433
RAK_REGION_CN470
RAK_REGION_RU864
RAK_REGION_IN865
RAK_REGION_EU868
RAK_REGION_US915
RAK_REGION_AU915
RAK_REGION_KR920
RAK_REGION_AS923
#define SMART_FARM_BAND (RAK_REGION_EU868)
#define SMART_FARM_DEVEUI {XXXXXXXXXX....}
#define SMART_FARM_APPEUI {0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00}
#define SMART_FARM_APPKEY {XXXXXXXXXX...}
/** Temperature & Humidity sensor **/
Bsec iaqSensor;
String output;
/** Packet buffer for sending */
uint8_t collected_data[64] = { 0 };
void recvCallback(SERVICE_LORA_RECEIVE_T * data)
if (data->BufferSize > 0) {
Serial.print("\r\n");
if (status == 0) {
Serial.println("Successfully sent");
} else {
Serial.println("Sending failed");
void setup()
delay(1000);
pinMode(LED_BUILTIN, OUTPUT);
iaqSensor.begin(BME68X_I2C_ADDR_LOW, Wire);
output = "\nBSEC library version " + String(iaqSensor.version.major) + "." + String(iaqSensor.version.minor) + "." + String(iaqSensor.version.major_bugfix) + "." + String(iaqSensor.version.minor_bugfix);
Serial.println(output);
checkIaqSensorStatus();
bsec_virtual_sensor_t sensorList[13] = {
BSEC_OUTPUT_IAQ,
BSEC_OUTPUT_STATIC_IAQ,
BSEC_OUTPUT_CO2_EQUIVALENT,
BSEC_OUTPUT_BREATH_VOC_EQUIVALENT,
BSEC_OUTPUT_RAW_TEMPERATURE,
BSEC_OUTPUT_RAW_PRESSURE,
BSEC_OUTPUT_RAW_HUMIDITY,
BSEC_OUTPUT_RAW_GAS,
BSEC_OUTPUT_STABILIZATION_STATUS,
BSEC_OUTPUT_RUN_IN_STATUS,
BSEC_OUTPUT_SENSOR_HEAT_COMPENSATED_TEMPERATURE,
BSEC_OUTPUT_SENSOR_HEAT_COMPENSATED_HUMIDITY,
BSEC_OUTPUT_GAS_PERCENTAGE
iaqSensor.updateSubscription(sensorList, 13, BSEC_SAMPLE_RATE_LP);
Serial.println("RAKwireless Smart Farm Example");
// OTAA Device EUI MSB first
uint8_t node_device_eui[8] = SMART_FARM_DEVEUI;
// OTAA Application EUI MSB first
uint8_t node_app_eui[8] = SMART_FARM_APPEUI;
// OTAA Application Key MSB first
uint8_t node_app_key[16] = SMART_FARM_APPKEY;
if (!api.system.lpm.set(1)) {
Serial.printf("LoRaWan Smart Farm - set low power mode is incorrect! \r\n");
return;
if (!api.lorawan.nwm.set()) {
Serial.printf("LoRaWan Smart Farm - set network working mode is incorrect! \r\n");
return;
if (!api.lorawan.appeui.set(node_app_eui, 8)) {
Serial.printf("LoRaWan Smart Farm - set application EUI is incorrect! \r\n");
return;
if (!api.lorawan.appkey.set(node_app_key, 16)) {
Serial.printf("LoRaWan Smart Farm - set application key is incorrect! \r\n");
return;
if (!api.lorawan.deui.set(node_device_eui, 8)) {
Serial.printf("LoRaWan Smart Farm - set device EUI is incorrect! \r\n");
return;
if (!api.lorawan.band.set(SMART_FARM_BAND)) {
Serial.printf("LoRaWan Smart Farm - set band is incorrect! \r\n");
return;
if (!api.lorawan.deviceClass.set(RAK_LORA_CLASS_A)) {
Serial.printf("LoRaWan Smart Farm - set device class is incorrect! \r\n");
return;
if (!api.lorawan.njm.set(RAK_LORA_OTAA)) // Set the network join mode to OTAA
Serial.printf("LoRaWan Smart Farm - set network join mode is incorrect! \r\n");
return;
if (!api.lorawan.join()) // Join to Gateway
Serial.printf("LoRaWan Smart Farm - join fail! \r\n");
return;
Serial.println("++++++++++++++++++++++++++");
Serial.println("RUI3 Environment Sensing");
// Print the header
output = "Timestamp [ms], IAQ, IAQ accuracy, Static IAQ, CO2 equivalent, breath VOC equivalent, raw temp[°C], pressure [hPa], raw relative humidity [%], gas [Ohm], Stab Status, run in status, comp temp[°C], comp humidity [%], gas percentage";
/** Wait for Join success */
api.lorawan.join();
delay(10000);
if (!api.lorawan.adr.set(true)) {
Serial.printf("LoRaWan Smart Farm - set adaptive data rate is incorrect! \r\n");
return;
if (!api.lorawan.rety.set(1)) {
Serial.printf("LoRaWan Smart Farm - set retry times is incorrect! \r\n");
return;
if (!api.lorawan.cfm.set(1)) {
Serial.printf("LoRaWan Smart Farm - set confirm mode is incorrect! \r\n");
return;
/** Check LoRaWan Status*/
Serial.printf("Duty cycle is %s\r\n", api.lorawan.dcs.get()? "ON" : "OFF"); // Check Duty Cycle status
Serial.printf("Packet is %s\r\n", api.lorawan.cfm.get()? "CONFIRMED" : "UNCONFIRMED"); // Check Confirm status
uint8_t assigned_dev_addr[4] = { 0 };
Serial.printf("Device Address is %02X%02X%02X%02X\r\n", assigned_dev_addr[0], assigned_dev_addr[1], assigned_dev_addr[2], assigned_dev_addr[3]); // Check Device Address
Serial.printf("Uplink period is %ums\r\n", SMART_FARM_PERIOD);
Serial.println("");
if (api.system.timer.create(RAK_TIMER_0, (RAK_TIMER_HANDLER)uplink_routine, RAK_TIMER_PERIODIC) != true) {
Serial.printf("LoRaWan Smart Farm - Creating timer failed.\r\n");
return;
if (api.system.timer.start(RAK_TIMER_0, SMART_FARM_PERIOD, NULL) != true) {
Serial.printf("LoRaWan Smart Farm - Starting timer failed.\r\n");
return;
/** Get sensor RAK1906 values */
unsigned long time_trigger = millis();
if (iaqSensor.run()) { // If new data is available
// Print the header
output = String(time_trigger);
output += ", " + String(iaqSensor.iaq);
output += ", " + String(iaqSensor.iaqAccuracy);
output += ", " + String(iaqSensor.staticIaq);
output += ", " + String(iaqSensor.co2Equivalent);
output += ", " + String(iaqSensor.breathVocEquivalent);
output += ", " + String(iaqSensor.rawTemperature);
output += ", " + String(iaqSensor.pressure);
output += ", " + String(iaqSensor.rawHumidity);
output += ", " + String(iaqSensor.gasResistance);
output += ", " + String(iaqSensor.stabStatus);
output += ", " + String(iaqSensor.runInStatus);
output += ", " + String(iaqSensor.temperature);
output += ", " + String(iaqSensor.humidity);
output += ", " + String(iaqSensor.gasPercentage);
} else {
float temp_f = iaqSensor.temperature;
float humid_f = iaqSensor.humidity;
float press_f = (iaqSensor.pressure / 100);
float gas_f = iaqSensor.staticIaq;
// Add battery voltage
float battery_reading = 0.0;
for (int i = 0; i < 10; i++)
battery_reading += api.system.bat.get(); // get battery voltage
battery_reading = battery_reading / 10;
Serial.printf("T %.2f H %.2f P %.2f G %.2f B %.2f\r\n", temp_f, humid_f, press_f, gas_f, battery_reading);
/** Cayenne Low Power LPP Payload */
lpp.reset();
lpp.addTemperature(3, temp_f);
lpp.addRelativeHumidity(4,humid_f);
lpp.addBarometricPressure(5,press_f);
lpp.addAnalogInput(6, gas_f);
lpp.addAnalogInput(7, battery_reading);
uint8_t data_len = 0;
data_len = lpp.getSize();
Serial.println("Data Packet:");
Serial.print("Bytes sent : ");
Serial.println(data_len);
uint8_t *payload = lpp.getBuffer();
for (unsigned char i = 0; i < data_len; i++)
Serial.print("0x");
Serial.print(payload[i], HEX);
Serial.print(" ");
Serial.println("---------------------");
/** Send the data package */
if (api.lorawan.send(data_len, lpp.getBuffer(), 2, true, 1)) {
Serial.println("Sending is requested");
} else {
void loop()
/* Destroy this busy loop and use timer to do what you want instead,
* so that the system thread can auto enter low power mode by api.system.lpm.set(1); */
api.system.scheduler.task.destroy();
// Helper function definitions
if (iaqSensor.bsecStatus != BSEC_OK) {
if (iaqSensor.bsecStatus < BSEC_OK) {
output = "BSEC error code : " + String(iaqSensor.bsecStatus);
for (;;)
errLeds(); /* Halt in case of failure */
} else {
output = "BSEC warning code : " + String(iaqSensor.bsecStatus);
if (iaqSensor.bme68xStatus != BME68X_OK) {
if (iaqSensor.bme68xStatus < BME68X_OK) {
output = "BME68X error code : " + String(iaqSensor.bme68xStatus);
for (;;)
} else {
output = "BME68X warning code : " + String(iaqSensor.bme68xStatus);
void errLeds(void)
delay(100);
delay(100);
