Issue:Chirpstack crashing
Setup:Default RAC7246
Server:RAC7246
Details:Using the standard default RAC7246 software the Chirpstack server is not available as an option. When you check if the Chirpstack server is running, if you run “chirpstack-application-server” it returns an ‘illegal instruction’. When you check the systemctl status of “chripstack-application-server” it has an error “failed with result ‘signal’” “(code=killed, signal=ILL)”. You would expect the ‘default’ software to run without error. Is there a fix for this?
