I was able to get a wind speed unit working on the Rak device. There are 2 thing I want to accomplish right now. First I would like to send this data from the test project for the wind speed over helium. How do I create a payload decoder for that example Rak 5811 0-5V? We basically stripped down the example and used it for an analog wind speed sensor connected to the pins on the board!
* @file RAK5811_0-5V.ino
* @author rakwireless.com
* @brief 0 to 5V analog input example.
* @version 0.1
* @date 2020-07-28
* @copyright Copyright (c) 2020
#include <Arduino.h>
#define NO_OF_SAMPLES 32
void setup()
time_t timeout = millis();
while (!Serial)
delay(100);
else
break;
/* WisBLOCK 5811 Power On*/
pinMode(WB_IO1, OUTPUT);
digitalWrite(WB_IO1, HIGH);
pinMode(WB_A0, INPUT);
analogReference(AR_INTERNAL_3_0);
analogOversampling(128);
void loop()
int i;
int mcu_ain_raw = 0;
int depths; // variable to store the value of oil depths
int average_raw;
float mcu_ain_voltage;
float voltage_sensor; // variable to store the value coming from the sensor
for (i = 0; i < NO_OF_SAMPLES; i++)
mcu_ain_raw += analogRead(WB_A0); // the input pin A1 for the potentiometerr
average_raw = mcu_ain_raw / i;
mcu_ain_voltage = average_raw * 3.0 / 1024; //raef 3.0V / 10bit ADC
//voltage_sensor = mcu_ain_voltage / 0.6; //WisBlock RAK5811 (0 ~ 5V). Input signal reduced to 6/10 and output
//depths = (voltage_sensor * 1000 - 574) * 2.5; //Convert to millivolt. 574mv is the default output from sensor
Serial.printf("-------average_value------ = %d\n", average_raw);
Serial.printf("-------voltage_sensor------ = %f\n", mcu_ain_voltage);
//Serial.printf("-------depths------ = %d mm\n", depths);
delay(2000);
Ideally though, I want to combine it to this projects code and send all of it to helium.
@file Environment_Monitoring.ino
@brief This sketch demonstrate how to get environment data from BME680
and send the data to lora gateway.
@version 0.1
@date 2020-07-28
#include <LoRaWan-RAK4630.h> // Click to install library: http://librarymanager/ALL#SX126x-Arduino
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BME680.h> // Click to install library: http://librarymanager/All#Adafruit_BME680
#include <U8g2lib.h> // Click to install library: http://librarymanager/ALL#u8g2
U8G2_SSD1306_128X64_NONAME_F_HW_I2C u8g2(U8G2_R0);
Adafruit_BME680 bme;
// RAK4630 supply two LED
#ifndef LED_BUILTIN
#define LED_BUILTIN 35
#endif
#ifndef LED_BUILTIN2
#define LED_BUILTIN2 36
#endif
#define LORAWAN_DATERATE DR_3 /*LoRaMac datarates definition, from DR_0 to DR_5*/
#define LORAWAN_TX_POWER TX_POWER_0 /*LoRaMac tx power definition, from TX_POWER_0 to TX_POWER_15*/
#define JOINREQ_NBTRIALS 15 /**< Number of trials for the join request. */
DeviceClass_t g_CurrentClass = CLASS_A; /* class definition*/
LoRaMacRegion_t g_CurrentRegion = LORAMAC_REGION_US915; /* Region:EU868*/
lmh_confirm g_CurrentConfirm = LMH_CONFIRMED_MSG; /* confirm/unconfirm packet definition*/
static lmh_param_t g_lora_param_init = {LORAWAN_ADR_OFF, LORAWAN_DATERATE, LORAWAN_PUBLIC_NETWORK, JOINREQ_NBTRIALS, LORAWAN_TX_POWER, LORAWAN_DUTYCYCLE_OFF};
// Foward declaration
void lorawan_join_fail(void);
static lmh_callback_t g_lora_callbacks = {BoardGetBatteryLevel, BoardGetUniqueId, BoardGetRandomSeed,
lorawan_rx_handler, lorawan_has_joined_handler, lorawan_confirm_class_handler, lorawan_join_fail
//OTAA keys !!!! KEYS ARE MSB !!!!
uint8_t nodeDeviceEUI[8] = {0xAC, 0x1F, 0x09, 0xFF, 0xFE, 0x05, 0x03, 0x3E};
uint8_t nodeAppEUI[8] = {0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
uint8_t nodeAppKey[16] = {};
//uint8_t nodeDeviceEUI[8] = {0x60, 0x81, 0xF9, 0x68, 0x19, 0x3A, 0x3D, 0xB3};
//uint8_t nodeAppEUI[8] = {0x60, 0x81, 0xF9, 0x08, 0x68, 0xAA, 0xB4, 0x3B};
//uint8_t nodeAppKey[16] = {0x5E, 0x46, 0xF7, 0x95, 0xE5, 0xA2, 0x2C, 0xA1, 0xC7, 0xF3, 0x63, 0x80, 0x55, 0xE7, 0xA6, 0x8F};
// ABP keys
uint32_t nodeDevAddr = 0x260116F8;
uint8_t nodeNwsKey[16] = {0x7E, 0xAC, 0xE2, 0x55, 0xB8, 0xA5, 0xE2, 0x69, 0x91, 0x51, 0x96, 0x06, 0x47, 0x56, 0x9D, 0x23};
uint8_t nodeAppsKey[16] = {0xFB, 0xAC, 0xB6, 0x47, 0xF3, 0x58, 0x45, 0xC7, 0x50, 0x7D, 0xBF, 0x16, 0x8B, 0xA8, 0xC1, 0x7C};
// Private defination
#define LORAWAN_APP_INTERVAL 60000 /**< Defines for user timer, the application data transmission interval. 20s, value in [ms]. */
TimerEvent_t appTimer;
static uint32_t count = 0;
void setup()
// Initialize the built in LED
pinMode(LED_BUILTIN, OUTPUT);
while (!Serial)
if ((millis() - serial_timeout) < 5000)
delay(100);
digitalWrite(LED_BUILTIN, !digitalRead(LED_BUILTIN));
else
break;
if (doOTAA)
Serial.println("Type: OTAA");
else
Serial.println("Type: ABP");
switch (g_CurrentRegion)
case LORAMAC_REGION_AS923:
break;
case LORAMAC_REGION_AU915:
break;
case LORAMAC_REGION_CN470:
break;
case LORAMAC_REGION_EU433:
break;
case LORAMAC_REGION_IN865:
break;
case LORAMAC_REGION_EU868:
break;
case LORAMAC_REGION_KR920:
break;
case LORAMAC_REGION_US915:
break;
// Initialize LoRa chip.
lora_rak4630_init();
/* bme680 init */
init_bme680();
u8g2.begin();
uint32_t err_code;
err_code = timers_init();
if (err_code != 0)
return;
// Setup the EUIs and Keys
if (doOTAA)
lmh_setDevEui(nodeDeviceEUI);
lmh_setAppEui(nodeAppEUI);
lmh_setAppKey(nodeAppKey);
else
lmh_setNwkSKey(nodeNwsKey);
lmh_setAppSKey(nodeAppsKey);
lmh_setDevAddr(nodeDevAddr);
// Initialize LoRaWan
err_code = lmh_init(&g_lora_callbacks, g_lora_param_init, doOTAA, g_CurrentClass, g_CurrentRegion);
if (err_code != 0)
return;
// Start Join procedure
u8g2.clearBuffer(); // clear the internal memory
u8g2.setFont(u8g2_font_ncenB10_tr); // choose a suitable font
u8g2.drawStr(20, 39, "Joining ...");
u8g2.sendBuffer(); // transfer internal memory to the display
lmh_join();
void loop()
// Put your application tasks here, like reading of sensors,
// Controlling actuators and/or other functions.
/**@brief LoRa function for failed Join event
/**@brief LoRa function for handling HasJoined event.
u8g2.drawStr(20, 39, "Joined");
//delay(2000);
if (ret == LMH_SUCCESS)
delay(1000);
TimerStart(&appTimer);
@param[in] app_data Pointer to rx data
m_lora_app_data.buffsize = 0;
lmh_send(&m_lora_app_data, g_CurrentConfirm);
//Not joined, try again later
return;
if (!bme.performReading()) {
return;
bme680_get();
if (error == LMH_SUCCESS)
count++;
else
count_fail++;
/**@brief Function for handling user timerout event.
send_lora_frame();
@details Initializes the timer module. This creates and starts application timers.
return 0;
void init_bme680(void)
Wire.begin();
if (!bme.begin(0x76)) {
Serial.println("Could not find a valid BME680 sensor, check wiring!");
return;
// Set up oversampling and filter initialization
bme.setTemperatureOversampling(BME680_OS_8X);
bme.setHumidityOversampling(BME680_OS_2X);
bme.setPressureOversampling(BME680_OS_4X);
bme.setIIRFilterSize(BME680_FILTER_SIZE_3);
bme.setGasHeater(320, 150); // 320*C for 150 ms
String data = "";
void bme680_get()
char oled_data[32] = {0};
Serial.print("result: ");
uint32_t i = 0;
double temp = bme.temperature;
double pres = bme.pressure / 100.0;
double hum = bme.humidity;
uint32_t gas = bme.gas_resistance;
data = "Tem:" + String(temp) + "C " + "Hum:" + String(hum) + "% " + "Pres:" + String(pres) + "KPa " + "Gas:" + String(gas) + "Ohms";
Serial.println(data);
// display bme680 sensor data on OLED
memset(oled_data, 0, sizeof(oled_data));
sprintf(oled_data, "T=%.2fC", temp);
u8g2.drawStr(3, 15, oled_data);
snprintf(oled_data, 64, "RH=%.2f%%", hum);
u8g2.drawStr(3, 30, oled_data);
sprintf(oled_data, "P=%.2fhPa", pres);
u8g2.drawStr(3, 45, oled_data);
sprintf(oled_data, "G=%dOhms", gas);
u8g2.drawStr(3, 60, oled_data);
uint16_t t = temp * 100;
uint16_t h = hum * 100;
uint32_t pre = pres * 100;
//result: T=28.25C, RH=50.00%, P=958.57hPa, G=100406 Ohms
m_lora_app_data.buffer[i++] = 0x01;
m_lora_app_data.buffer[i++] = (uint8_t)(t >> 8);
m_lora_app_data.buffer[i++] = (uint8_t)t;
m_lora_app_data.buffer[i++] = (uint8_t)(h >> 8);
m_lora_app_data.buffer[i++] = (uint8_t)h;
m_lora_app_data.buffer[i++] = (uint8_t)((pre & 0xFF000000) >> 24);
m_lora_app_data.buffer[i++] = (uint8_t)((pre & 0x00FF0000) >> 16);
m_lora_app_data.buffer[i++] = (uint8_t)((pre & 0x0000FF00) >> 8);
m_lora_app_data.buffer[i++] = (uint8_t)(pre & 0x000000FF);
m_lora_app_data.buffer[i++] = (uint8_t)((gas & 0xFF000000) >> 24);
m_lora_app_data.buffer[i++] = (uint8_t)((gas & 0x00FF0000) >> 16);
m_lora_app_data.buffer[i++] = (uint8_t)((gas & 0x0000FF00) >> 8);
m_lora_app_data.buffer[i++] = (uint8_t)(gas & 0x000000FF);
m_lora_app_data.buffsize = i;
