So WB_IO2 on RAK19007 is used to switch 3V3S on and off. If a RAK1906 sensor is used in Slot B the documentation says it will use WB_IO2 for an output pulse. Is this correct?
Do I have to put the RAK1906 in a different slot ?
I see. thanks! The documentation mentioned something about an output pulse but clearly that does not apply.
