Details:
hi~!!
When I firmware update via LoRaButton, the program is down.
Before executing it, using stm32, boot file? We performed something like that normally.
And when you try to install firmware with the lorabutton, it will no longer run as the sentence starts with the same sentence as start sending.
Did I miss anything?
Can you check what is the current RAK7205 FW your device have?
The method of update the FW will depend on your current FW. If you will upload the latest FW, you should use either RAK DFU Tool or STM32CubeProgrammer.
