What product do you wish to discuss? RAK4631
What firmware are you using? VSCode/PlatformIO
What firmware version? No support do AT, Arduino BSP
Computer OS? (MacOS, Linux, Windows) Windows
What Computer OS version? Windows 11
How often does the problem happen? Yes
How can we replicate the problem? Yes
Provide source code if custom firmware is used or link to example if RAKwireless example code is used.
I had a code in traditional shape “setup and loop”, but when I split the code in Libraries, no serial monitor output is working. The monitor serial output that I get, it is a “serial.print” that I have in the “loop()”
I already tried to change the “monitor_dtr = 0 and monitor_rts = 0”, but no effect.
Any ideas?
The partial code is below:
How the code was splited in Libraries:
The serial monitor output:
Platformio.ini
; PlatformIO Project Configuration File
; Build options: build flags, source filter
; Upload options: custom upload port, speed and extra flags
; Library options: dependencies, extra library storages
; Advanced options: extra scripting
; Please visit documentation for the other options and examples
; https://docs.platformio.org/page/projectconf.html
[upload_settings]
device_eui = '0xAC, 0x1F, 0x09, 0xFF, 0xFE, 0x0C, 0xF0, 0x41'
app_eui = '0xAC, 0x1F, 0x09, 0xFF, 0x00, 0x00, 0x00, 0x02'
app_key = '0x4B, 0x41, 0x70, 0x70, 0x6C, 0x69, 0x63, 0x61, 0x74, 0x69, 0x6F, 0x6E, 0x20, 0x4B, 0x65, 0x79'
[env:wiscore_rak4631]
platform = nordicnrf52
board = wiscore_rak4631
framework = arduino
; upload_port = COM16
; monitor_speed = 115200
; monitor_dtr = 0
; monitor_rts = 0
lib_deps =
sparkfun/SparkFun LIS3DH Arduino Library @ ^1.0.3
adafruit/Adafruit BME680 Library @ ^2.0.4
sparkfun/SparkFun u-blox GNSS Arduino Library @ ^2.2.25
beegee-tokyo/SX126x-Arduino @ ^2.0.24
; build_type = debug
build_flags =
; -DCFG_DEBUG=2
-D MONITOR_SPEED=115200
-D UPLOAD_SPEED=115200
; LEDs
-D LED_GREEN=35
-D PIN_LED1=35
-D LED_BLUE=36
-D PIN_LED2=36
-D LED_STATE_ON=1
; calibração das variáveis ambientais
-D SEALEVELPRESSURE_HPA=1010.0
; Desabilitar INT1/INT2 no RAK1904 para evitar conflito com RAK5801
; INT1 de RAK1904
; -D LIS3DH_CTRL_REG3=0x25
; INT2 de RAK1904 .
; -D LIS3DH_CTRL_REG6=0x25
; LoRa
-D SCHED_MAX_EVENT_DATA_SIZE=APP_TIMER_SCHED_EVENT_DATA_SIZE ; /**< Maximum size of scheduler events. */
-D SCHED_QUEUE_SIZE=60 ; /**< Maximum number of events in the scheduler queue. */
-D LORAWAN_DATERATE=DR_0
-D LORAWAN_TX_POWER=TX_POWER_0
-D JOINREQ_NBTRIALS=3
-D DEV_EUI=${upload_settings.device_eui}
-D APP_EUI=${upload_settings.app_eui}
-D APP_KEY=${upload_settings.app_key}
; Private defination
-D LORAWAN_APP_DATA_BUFF_SIZE=64 ; tamanho do buffer para o payload a ser enviado via LoRa
-D LORAWAN_APP_INTERVAL=20000 ; definição do temporizador do intervalo de transmissão dos dados da aplicação. 20 mili segundos>
The main.h:
* 1) rastreador baseado em GPS: latitude, longitude e altura
* 2) um acelerômetro: quantidade de movimento
* 3) medição de variáveis ambientais: temperatura e humidade
* 4) pressão duas linhas pneumáticas: através da leitura de um transdutor de pressão para variação de corrente 4-20 mA
// bibliotecas do sistema
#ifndef _ARDUINO_H
#define _ARDUINO_H
#include <Arduino.h>
#endif
#ifndef _STDINT_H
#define _STDINT_H
#include <stdint.h> // usa int sem sinal, por exemplo uint8_t, que ocupa apenas 1 byte
#endif
#ifndef _WIRE_H
#define _WIRE_H
#include <Wire.h>
#endif
#ifndef _SPI_H
#define _SPI_H
#include <SPI.h>
#endif
// Bibliotecas personalizadas
#include <RAK4631.h>
#include <RAK1904.h>
#include <RAK1906.h>
#include <RAK12500.h>
#include <RAK15007.h>
// sensores
class Sensores
public:
String TipoMod [5] = {"RAK4631","RAK1904","RAK1906","RAK5801","RAK12500"};
uint8_t BatInt, BatDec, HumVal, TempInt, TempDec, PresBarInt, PresBarDec ;
uint8_t BatCarga [5] = {1,116,BatInt,BatDec,0};
uint8_t Hum [4] = {6,104,HumVal,2};
uint8_t Temp [5] = {7,103,TempInt,TempDec,2};
uint8_t PresBar [5] = {8,115,PresBarInt, PresBarDec,2};
The main.cpp:
#include <main.h>
uint8_t count1=0;
void setup()
void IniciaAmbiente(void); // Incia porta Serial, Temporizador
void bme680_init(void); // Inicia RAK1906 BME680 sensor de variáveis ambientais
void IniciaGNSS(void); // Inicia RAK12500 sensor de geo-posicionamento
void IniciaAcel(void); // Inidiq RAK1904 sensor de movimento
void IniciaPress(void); // Inicial o sensor de variação de corrente 4-20Ma WisBLOCK 5801
void LoRaInit(void); // Inicia LoRa
void loop()
count1++;
Serial.print("========= Saida no Monitor ");
Serial.print(String(count1));
Serial.println("=======================");
vTaskDelay(pdMS_TO_TICKS(1000));
void LeAcel(void); // Le quantidade de movimento nos eixos X, Y e Z
void LeAmbiente(void); // Le variáveis ambientais
void LeGNSS(void); // Le o geo-posicionamento via GPS
float LePress(void); // Le do transdutor de pressão das linhas pneumáticas da composição
The RAK1904 library:
RAK1904.h
#ifndef _RAK1904_H
#define _RAK1904_H
#ifndef _ARDUINO_H
#define _ARDUINO_H
#endif
#ifndef _STDINT_H
#define _STDINT_H
#endif
#ifndef _WIRE_H
#define _WIRE_H
#include <Wire.h>
#endif
// Bibliotecas do Firmware
// RAK1904 acelerômetro
#include <SparkFunLIS3DH.h> //http://librarymanager/All#SparkFun-LIS3DH
LIS3DH SensorTwo(I2C_MODE, 0x18);
void LeAcel(void);
#endif
RAK1904.cpp
if (SensorTwo.begin() != 0)
Serial.println("Problema iniciar o sensor no endereço 0x18.");
else
Serial.println("Sensor iniciado no endereço RAK1904 no endereço 0x18.");
// Set low power mode
uint8_t data_to_write = 0;
SensorTwo.readRegister(&data_to_write, LIS3DH_CTRL_REG1);
data_to_write |= 0x08;
SensorTwo.writeRegister(LIS3DH_CTRL_REG1, data_to_write);
vTaskDelay(pdMS_TO_TICKS(100));
data_to_write = 0;
SensorTwo.readRegister(&data_to_write, 0x1E);
data_to_write |= 0x90;
SensorTwo.writeRegister(0x1E, data_to_write);
void LeAcel(void)
Serial.println("========= Quantidade de Movimento============");
Serial.print(" X(g) = ");
Serial.println(SensorTwo.readFloatAccelX(), 4);
Serial.print(" Y(g) = ");
Serial.println(SensorTwo.readFloatAccelY(), 4);
Serial.print(" Z(g)= ");
Serial.println(SensorTwo.readFloatAccelZ(), 4);
