Issue:
when set to region AS923, dwell time defaults are set to true
Setup:
Lora Module: RAK4200 fw verion 3.2.0.16
Server:
Chirpstack NS version 3.16.4
Details:
When region is set to any sub-band of AS923, not ablle to set dr to 0 or 1:
at+set_config=lora:dr:0
ERROR: 82
at+set_config=lora:dr:1
ERROR: 82
at+set_config=lora:dr:2
OK
I assume DwellTime400ms is set to true by default for AS923.
My questions:
1, is my assumption correct?
2, if the answer to my 1st question is true, is it possible to change them back to false( no DwellTime) by default?
Thanks.
Good to know that instead of failing the JOIN at DR0 or DR1, it failed the set_config of DR0 and DR1 before the JOIN.
However, there is another evidence supporting my assumption that dwell-times are default to ‘true’ : I can not send packets larger than 19 bytes at DR2.
Please let me know if this restriction is not caused by the dwell-time defaults.
We are able to modify the chirpstack network server configurations to change the dwell-time on the lora module after it joins the network.
My questions is: since those dwell-time settings are going to be determined by the server, why aren’t they both default to ‘false’ like other regions?
