Issue: Gateway disconnected TTN Server
Setup: Gateway RAK7248
Server: TTN Server
Details: after setting with guideline status show Disconnected
Server: TTN Server
Hello @Suphika ,
You can use this guide to set up your gateway with TTN : RAK7248 Supported LoRa Network Servers | RAKwireless Documentation Center
Best Regards,
Nikola Semov
Yes, I followed that process. But my gateway has status Disconnected all the time since the first time sticking to the configure
Suphika
Hi I just want to know if you found the solution? If so, please let me know, we are also having the same issue.
