I have two end nodes that are running the EXACT same firmware (utilizing an RN2903 in unconfirmed
mode), but the devAddr are different between the two.
As far as I can tell, the setup looks consistent in the web UI, but when my node SN3 send an uplink to the gateway, and downlink is triggered. SN2 does not have that reaction (which I think is the right way to go).
I’ve looked at the debug from the GUI, and I don’t see anything different in the uploads between the two units. Is there something in these two pictures that can point me to what I am doing wrong?
I just realized that I can get a little more information (I haven’t had time to digest it yet) if I look at the frames on the device’s page, not the gateway. It is too long to fit in one image, so here is a couple
I just noticed that adr is false on the node that is having this weird response, but true on the other one. I am guessing that is the issues… I was going to try to make the change, but I see that that isn’t something set by me. I’ll look into why that might be happening…
edit
Well that went no where fast. I turned on ADR, but that didn’t change the downlink trigger
Dear garengllc,
If the parameters of the connection are inconsistent, the addR he assigns will be different, which is normal.
The ADR also changes according to the signal, rather than changing every time.
edit
I turned off my second unit so hay I know that they aren’t transmitting at the same time for sure. It is still having the same issue. So it is not that.
Dear garengllc,
I can understand your question is on the setting of ADR, right?
Both the node and the server have places to set adRs, and you need to make sure that these are consistent!
