I tried to integrate all of those suggestions and I ended up with this code:
* @file RUI3-Signal-Meter-P2P-LPWAN.ino
* @author Bernd Giesecke ([email protected])
* @brief Simple signal meter for LoRa P2P and LoRaWAN
* @version 0.1
* @date 2023-11-23
* @copyright Copyright (c) 2023
#include "app.h"
#define OTAA_BAND (RAK_REGION_US915)
uint8_t OTAA_DEVEUI[8] = { 0xAC,0x1F,0x09,0xFF,0xFE,0x1C,0xCE,0xE4 };
uint8_t OTAA_APPEUI[8] = { 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00 };
uint8_t OTAA_APPKEY[16] = {
0x3F,0x00,0x9C,0x60, 0x61,0xEE,0x0F,0x38,
0xFB,0x29,0x27,0xCD, 0x4E,0xFC,0xEE,0x95
/** Last RX SNR level*/
volatile int8_t last_snr = 0;
/** Last RX RSSI level*/
volatile int16_t last_rssi = 0;
/** Link check result */
volatile uint8_t link_check_state;
/** Demodulation margin */
volatile uint8_t link_check_demod_margin;
/** Number of gateways */
volatile uint8_t link_check_gateways;
/** Sent packet counter */
volatile int32_t packet_num = 0;
/** Lost packet counter (only LPW mode)*/
volatile int32_t packet_lost = 0;
/** Last RX data rate */
volatile uint8_t last_dr = 0;
/** TX fail reason (only LPW mode)*/
volatile int32_t tx_fail_status;
/** LoRa mode */
bool lorawan_mode = true;
/** Flag if confirmed packets or LinkCheck should be used */
bool use_link_check = true;
/** Flag if OLED was found */
bool has_oled = false;
/** Buffer for OLED output */
char line_str[256];
/** Flag for display handler */
uint8_t display_reason;
* @brief Send a LoRaWAN packet
* @param data unused
void send_packet(void *data)
if (api.lorawan.njs.get())
MYLOG("APP", "Send packet");
uint8_t payload[4] = {0x01, 0x02, 0x03, 0x04};
// Always send confirmed packet to make sure a reply is received
api.lorawan.send(4, payload, 2, true, 8);
// if (use_link_check)
// // Linkcheck is enabled, send an unconfirmed packet
// api.lorawan.send(4, payload, 2, false);
// else
// // Linkcheck is disabled, send a confirmed packet
// api.lorawan.send(4, payload, 2, true, 8);
else
MYLOG("APP", "Not joined, don't send packet");
* @brief Display handler
* @param reason 1 = RX packet display
* 2 = TX failed display (only LPW mode)
* 3 = Join failed (only LPW mode)
* 4 = Linkcheck result display (only LPW LinkCheck mode)
* 5 = Join success (only LPW mode)
void handle_display(void *reason)
/** Update header and battery value */
if (has_oled)
rak1921_clear();
sprintf(line_str, "RAK Signal Meter - B %.2fV", api.system.bat.get());
rak1921_write_header(line_str);
// Get the wakeup reason
uint8_t *disp_reason = (uint8_t *)reason;
// Check if we have a reason
if (disp_reason == NULL)
Serial.println("Bug in code!");
else if (disp_reason[0] == 1)
// MYLOG("APP", "RX_EVENT %d\n", disp_reason[0]);
// RX event display
if (g_custom_parameters.test_mode == 1)
if (has_oled)
sprintf(line_str, "LPW CFM mode");
rak1921_write_line(0, 0, line_str);
sprintf(line_str, "Sent %d", packet_num);
rak1921_write_line(1, 0, line_str);
sprintf(line_str, "Lost %d", packet_lost);
rak1921_write_line(1, 64, line_str);
sprintf(line_str, "DR %d", last_dr);
rak1921_write_line(2, 0, line_str);
sprintf(line_str, "RSSI %d", last_rssi);
rak1921_write_line(3, 0, line_str);
sprintf(line_str, "SNR %d", last_snr);
rak1921_write_line(3, 64, line_str);
sprintf(line_str, "----------");
rak1921_write_line(4, 0, line_str);
rak1921_display();
Serial.println("LPW CFM mode");
Serial.printf("Packet # %d RSSI %d SNR %d\n", packet_num, last_rssi, last_snr);
Serial.printf("DR %d\n", last_dr);
else
if (has_oled)
sprintf(line_str, "LoRa P2P mode");
sprintf(line_str, "Received packets %d", packet_num);
sprintf(line_str, "F %.3f", (api.lora.pfreq.get() / 1000000.0));
sprintf(line_str, "SF %d", api.lora.psf.get());
sprintf(line_str, "BW %d", (api.lora.pbw.get() + 1) * 125);
rak1921_write_line(4, 64, line_str);
rak1921_display();
Serial.println("LPW P2P mode");
Serial.printf("F %.3f SF %d BW %d\n",
(float)api.lora.pfreq.get() / 1000000.0,
api.lora.psf.get(),
else if (disp_reason[0] == 2)
// MYLOG("APP", "TX_ERROR %d\n", disp_reason[0]);
digitalWrite(LED_BLUE, HIGH);
if (has_oled)
sprintf(line_str, "Lost %d", packet_num, packet_lost);
sprintf(line_str, "TX failed with status %d", tx_fail_status);
Serial.printf("Packet %d\n", packet_num);
Serial.printf("TX failed with status %d\n", tx_fail_status);
switch (tx_fail_status)
case RAK_LORAMAC_STATUS_ERROR:
sprintf(line_str, "Service error");
break;
case RAK_LORAMAC_STATUS_TX_TIMEOUT:
sprintf(line_str, "TX timeout");
break;
case RAK_LORAMAC_STATUS_RX1_TIMEOUT:
sprintf(line_str, "RX1 timeout");
break;
case RAK_LORAMAC_STATUS_RX2_TIMEOUT:
sprintf(line_str, "RX2 timeout");
break;
case RAK_LORAMAC_STATUS_RX1_ERROR:
sprintf(line_str, "RX1 error");
break;
case RAK_LORAMAC_STATUS_RX2_ERROR:
sprintf(line_str, "RX2 error");
break;
case RAK_LORAMAC_STATUS_JOIN_FAIL:
sprintf(line_str, "Join failed");
break;
case RAK_LORAMAC_STATUS_DOWNLINK_REPEATED:
sprintf(line_str, "Dowlink frame error");
break;
case RAK_LORAMAC_STATUS_TX_DR_PAYLOAD_SIZE_ERROR:
sprintf(line_str, "Payload size error");
break;
case RAK_LORAMAC_STATUS_DOWNLINK_TOO_MANY_FRAMES_LOSS:
sprintf(line_str, "Fcnt loss error");
break;
case RAK_LORAMAC_STATUS_ADDRESS_FAIL:
sprintf(line_str, "Adress error");
break;
case RAK_LORAMAC_STATUS_MIC_FAIL:
sprintf(line_str, "MIC error");
break;
case RAK_LORAMAC_STATUS_MULTICAST_FAIL:
sprintf(line_str, "Multicast error");
break;
case RAK_LORAMAC_STATUS_BEACON_LOCKED:
sprintf(line_str, "Beacon locked");
break;
case RAK_LORAMAC_STATUS_BEACON_LOST:
sprintf(line_str, "Beacon lost");
break;
case RAK_LORAMAC_STATUS_BEACON_NOT_FOUND:
sprintf(line_str, "Beacon not found");
break;
default:
sprintf(line_str, "Unknown error");
break;
Serial.printf("%s\n", line_str);
Serial.printf("Lost %d packets\n", packet_lost);
if (has_oled)
rak1921_display();
else if (disp_reason[0] == 3)
// MYLOG("APP", "JOIN_ERROR %d\n", disp_reason[0]);
if (has_oled)
sprintf(line_str, "LPW mode");
rak1921_write_line(1, 0, (char *)"!!!!!!!!!!!!!!!!!!!");
rak1921_write_line(2, 0, (char *)"!!!!!!!!!!!!!!!!!!!");
rak1921_write_line(4, 0, (char *)"!!!!!!!!!!!!!!!!!!!");
rak1921_display();
else if (disp_reason[0] == 5)
// MYLOG("APP", "JOIN_SUCCESS %d\n", disp_reason[0]);
if (has_oled)
sprintf(line_str, "Device joined network");
rak1921_display();
else if (disp_reason[0] == 4)
// MYLOG("APP", "LINK_CHECK %d\n", disp_reason[0]);
// LinkCheck result event display
if (has_oled)
sprintf(line_str, "LPW LinkCheck %s", link_check_state == 0 ? "OK" : "NOK");
if (link_check_state == 0)
sprintf(line_str, "Demod Margin %d", link_check_demod_margin);
rak1921_write_line(2, 64, line_str);
sprintf(line_str, "%d GW(s)", link_check_gateways);
sprintf(line_str, "DR %d", api.lorawan.dr.get());
else
sprintf(line_str, "LinkCheck result %d ", link_check_state);
switch (link_check_state)
break;
break;
break;
break;
break;
break;
break;
break;
break;
break;
break;
break;
break;
break;
break;
break;
default:
break;
rak1921_display();
Serial.printf("LinkCheck %s\n", link_check_state == 0 ? "OK" : "NOK");
Serial.printf("GW # %d Demod Margin %d\n", link_check_gateways, link_check_demod_margin);
digitalWrite(LED_GREEN, LOW);
* @brief Join network callback
* @param status status of join request
void join_cb_lpw(int32_t status)
if (status != 0)
display_reason = 3;
api.system.timer.start(RAK_TIMER_1, 250, &display_reason);
else
display_reason = 5;
* @brief Receive callback for LoRa P2P mode
* @param data structure with RX packet information
void recv_cb_p2p(rui_lora_p2p_recv_t data)
digitalWrite(LED_GREEN, HIGH);
last_rssi = data.Rssi;
last_snr = data.Snr;
packet_num++;
display_reason = 1;
* @brief Receive callback for LoRaWAN mode
void recv_cb_lpw(SERVICE_LORA_RECEIVE_T *data)
last_rssi = data->Rssi;
last_snr = data->Snr;
last_dr = data->RxDatarate;
packet_num++;
if (!use_link_check)
display_reason = 1;
* @brief Send finished callback for LoRaWAN mode
* @param status
void send_cb_lpw(int32_t status)
if (status != RAK_LORAMAC_STATUS_OK)
MYLOG("APP", "LMC status %d\n", RAK_LORAMAC_STATUS_OK);
tx_fail_status = status;
packet_lost++;
display_reason = 2;
* @brief Linkcheck callback
* @param data structure with the result of the Linkcheck
void linkcheck_cb_lpw(SERVICE_LORA_LINKCHECK_T *data)
// MYLOG("APP", "linkcheck_cb_lpw\n");
link_check_state = data->State;
link_check_demod_margin = data->DemodMargin;
link_check_gateways = data->NbGateways;
if (data->State != 0)
packet_lost++;
display_reason = 4;
* @brief Setup routine
void setup(void)
api.lorawan.join(0, 0, 0, 0);
pinMode(LED_GREEN, OUTPUT);
pinMode(LED_BLUE, OUTPUT);
if (!api.lorawan.appeui.set((uint8_t *)OTAA_APPEUI, 8)) {
Serial.println("Failed to set AppEUI");
return;
if (!api.lorawan.appkey.set((uint8_t *)OTAA_APPKEY, 16)) {
Serial.println("Failed to set AppKey");
return;
if (!api.lorawan.deui.set((uint8_t *)OTAA_DEVEUI, 8)) {
Serial.println("Failed to set DevEUI");
return;
if (!api.lorawan.band.set(OTAA_BAND)) {
Serial.printf("LoRaWan OTAA - set band is incorrect! \r\n");
return;
sprintf(line_str, "RUI3_Tester_V%d.%d.%d", SW_VERSION_0, SW_VERSION_1, SW_VERSION_2);
api.system.firmwareVersion.set(line_str);
// Check if OLED is available
Wire.begin();
has_oled = init_rak1921();
if (has_oled)
#ifndef RAK3172
while (!Serial.available())
if ((millis() - serial_timeout) < 5000)
delay(100);
digitalWrite(LED_GREEN, !digitalRead(LED_GREEN));
else
break;
#else
delay(5000);
#endif
digitalWrite(LED_BLUE, LOW);
if (!has_oled)
MYLOG("APP", "No OLED found");
// Initialize custom AT commands
if (!init_status_at())
MYLOG("APP", "Failed to initialize Status AT command");
if (!init_interval_at())
MYLOG("APP", "Failed to initialize Send Interval AT command");
if (!init_test_mode_at())
MYLOG("APP", "Failed to initialize Test Mode AT command");
// Get saved custom settings
if (!get_at_setting())
MYLOG("APP", "Failed to read saved custom settings");
// Setup callbacks and timers depending on test mode
switch (g_custom_parameters.test_mode)
default:
Serial.println("Invalid test mode, use LinkCheck");
if (has_oled)
sprintf(line_str, "Invalid test mode");
sprintf(line_str, "Using LinkCheck");
rak1921_display();
case MODE_LINKCHECK:
set_linkcheck();
break;
case MODE_CFM:
set_cfm();
break;
case MODE_P2P:
set_p2p();
break;
if (lorawan_mode)
api.system.timer.create(RAK_TIMER_0, send_packet, RAK_TIMER_PERIODIC);
if (g_custom_parameters.send_interval != 0)
api.system.timer.start(RAK_TIMER_0, g_custom_parameters.send_interval, NULL);
api.system.timer.create(RAK_TIMER_1, handle_display, RAK_TIMER_ONESHOT);
else
// If LoRaWAN, start join if required
if (lorawan_mode)
if (!api.lorawan.njs.get())
api.lorawan.join();
MYLOG("APP", "Start testing");
// Enable low power mode
api.system.lpm.set(1);
* @brief Loop (unused)
void loop(void)
api.system.sleep.all();
* @brief Set the module for LoRaWAN Confirmed Packet testing
void set_cfm(void)
MYLOG("APP", "Found CFM Mode");
use_link_check = false;
// Force LoRaWAN mode (might cause restart)
api.lorawan.nwm.set();
// Register callbacks
api.lorawan.registerRecvCallback(recv_cb_lpw);
api.lorawan.registerSendCallback(send_cb_lpw);
api.lorawan.registerJoinCallback(join_cb_lpw);
// Set confirmed packet mode
api.lorawan.cfm.set(true);
// Disable LinkCheck
api.lorawan.linkcheck.set(0);
if (!api.lorawan.join(1, 1, 10, 50))
MYLOG("APP", "Failed to start JOIN");
* @brief Set the module for LoRaWAN LinkCheck testing
void set_linkcheck(void)
MYLOG("APP", "Found LinkCheck Mode");
api.lorawan.registerLinkCheckCallback(linkcheck_cb_lpw);
// Set unconfirmed packet mode
api.lorawan.cfm.set(false);
api.lorawan.linkcheck.set(2);
* @brief Set the module for LoRa P2P testing
void set_p2p(void)
MYLOG("APP", "Found P2P Mode");
lorawan_mode = false;
if (!api.lorawan.join(0, 0, 10, 50))
MYLOG("APP", "Failed to stop JOIN");
if (!api.lora.precv(0))
MYLOG("APP", "Failed to stop P2P RX");
// Force LoRa P2P mode (might cause restart)
if (!api.lora.nwm.set())
MYLOG("APP", "Failed to set P2P Mode");
api.lora.registerPRecvCallback(recv_cb_p2p);
// Enable RX mode
api.lora.precv(65533);
However I still get random DevEUI and AppEUIs being generated:
