Hi. Could you please let me know what is the max voltage that I can put on pin WB_A0 ADC on a RAK13002 attached to a RAK5005 WisBlock and RAK4630.
I have a CT that I want to wrap around a grid line to measure the (solar) export current. The CT is rated 120A/40mA 10 ohms. I also want to read the mains AV voltage (240v AC).
Any help would be gratefully appreciated. Thank you.
Beside of that, the input voltage should never ever go higher than the supply voltage of the RAK4631, which is 3.3V.
Keep in mind that WB_A0 is connected to the battery over a resistor to measure the battery voltage and that you cannot use it to measure external voltages, unless you remove a resistor on the base board. It is recommended to use WB_A1 instead.
