I have a RAK7268C which is connected to The Things Stack Cloud using Basics Station. When I set it up via the webinterface on the RAK7268C it works like it should.
If I want to add my gateway under a location in WisDM, then I need to setup a network configuration. This is a little bite weird because each gateway need it’s own API Key so how would that work, if I want to add multiple gateways to a single location? It seems like that the setup on WisDM will overwrite everything you have done on your local gateway.
