Hello guys,
for some reason the WISDM is injecting “Bearer Authorization:” right after Authorization under client token in loRa Network section which breaks the connection with TTN as this is not a valid token… and it is not allowing me to edit the code in wisDM site, even fixing it locally gets reversed after few minutes…
Can you please explain how to fix the issue?
when i change it locally to the below it works but soon after it breaks and the Bearer Authorization appears in the token…
my gateway info:
