Hello!
Is it possible to deploy a WisGate Connect with a RAK5802 RS458 Modbus Interface behaving as a Modbus RTU Slave?
I have a customer who is requesting the deployment of a private LoRaWAN Network inside a manufacturing plant to monitor several variables across the site. However, the main requirement is that the measurements of the wireless LoRa sensors must be made available to a legacy system which communicates through Modbus RTU. The old system will behave as a Modbus Master and the WisGate Connect would be a modbus RTU Slave which provides current sensor measurements to the modbus master on demand.
Is this possible with the WisGate Connect? And if not, is this achievable with any other RAK gateway?
Thank you for your help!
