Wisgate Edge Lite 2 + mqtt.js
Hello RAK-community,
so i am pretty new to lora and I am learning it for my thesis that starts in two weeks…
So I bought the Wisgate Edge Lite 2 and 2x temp/humid sensors. My goal is to send data do the lora gateway and display the data on a website using mqtt.js.
I am very confused if the Wisgate can be used as a mqtt broker or if it is only possible to use the mqtt bridge, because I am not able to connect to my lora gateway via mqtt.js.
So is this even possible to achieve or do I have to setup a raspberry pi and configure a mqtt broker there and use the mqtt bridge of the lora gateway to forward the data?
Thank you in advance.
