I am planning to buy the WisGate Edge Lite 2 but I need to make sure that node whitelisting option is available with it. If so, is it also available in the WisDM in order to update the whitelist remotely?
I cannot find anything about this in the documentation.
not sure what you mean by whitelisting nodes, but if the node is not added to the application it will not be allowed to join… same goes for local server or TTN…
Hello @Civilduino the white list mode is available in all RAK Edge gateways in Packet Forwarder mode. As for now, it is not available in the WisDM, but will be added soon.
Hello @velev, can you point me to documentation or screenshots as to where the whitelist functionality can be found? I looked around the menus and was not able to find it. I have a RAK7268C.
My goal is to do exactly what @Civilduino is trying to do - i.e. save data when using a cellular connection.
