Wismesh Solar repeater with 3401+ 13302 not charging on solar
  • What product do you wish to discuss? RAK4631, RAK3372, RAK11200, RAK11310, RAK11722?
  • What firmware are you using? (RUI3 or Arduino BSP or other IDE (e.g. STM32CubeIDE)?
  • What firmware version? Can it be obtained with AT+VER=?
  • Computer OS? (MacOS, Linux, Windows)
  • What Computer OS version?
  • How often does the problem happen?
  • How can we replicate the problem?
  • Provide source code if custom firmware is used or link to example if RAKwireless example code is used.
I recently installed a wismesh solar repeater with the high output board in it for Meshcore . It will not charge through the solar at all. It gets full sun and should be able to charge the battery. Anyone else run into this issue? Solar panel and battery connections are both on correct.
Please open a ticket with [email protected].
