You’re welcome and please see below my comments on points you listed plus some extra infos My apologises for the long delay to answer but I have been quite overbusy with work
Well I resetted using terminal and AT command (it’s strange as it wast already able to accept AT commands but Wistoolbox had difficulties to communicate with module. Once module resetted, no more communication problem with Wistoolbox !).
Nope templates part works fine now, I can create, edit templates and then push them on the board without issues !
Nope you’re correct for these two points. It would be nice also the App contains all Python libraries it needs to do properly fw upgrades Once installed libs missing in system, Wistoolbox is able to flash fw properly
An other bug: if program loaded in Wisblock sends some message on console port, it’s displayed in the Device button of Wistoolbox (it’s mainly cosmetic as it doesn’t affect ability to connect !).
Hope it helps and impatient to be able to try next release of it
Well basically it was quite simple, I followed the tutorial (sorry can’t find back right now the link on docs.rakwireless.com) for manual flash of firmwares that indicates python version needed (at least version 3) and libs to go with ! Once done, no problem to flash fw from Wistoolbox
Is there a way to get notified when a new beta is avalaible ? out of checking from time to time downloads.rakwireless.com
