What firmware are you using? RUI_4.2.1_RAK3172-E. Same issue with Arduino BSP, Arduino IDE, or VS Code (Arduino Framework)
What firmware version? Can it be obtained with AT+VER=? (Device is non-responsive to any AT commands (AT enabled is ON in IDE)
Computer OS? ( Windows 10)
How often does the problem happen? Consistently
I have two RAK3172 devices now that power up and then seem to possibly get stuck in sleep mode ( LPMLVL=2)? I am unable to upload even a simple example program (e.g. Arduino indicates failure to detect baud rate, VS Code just times out). I’m using an FTDI USB to serial connection to UART2.
When I press RESET the following prints out on the serial monitor (or WisToolBox RAK3172 console if I manually select a RAK3172 device).
RAKwireless RAK3172-E
Version: RUI_4.2.1_RAK3172-E
Current Work Mode: LoRaWAN.
I’ve tried using STM32CubeProgrammer to restore the boot loader and RUI firmware and it indicated a successful download to the device (Note: I did not select to fully erase the device first). I’ve tried manually forcing BOOT mode with the boot pin held high and tapping the reset.
The message after a reset demonstrates a valid serial to USB to terminal connection. But the RAK3172/RUI does not respond to any AT commands (including ATZ).
ATZ, AT+RUN, and AT+RESET have no effect.
Your troubleshooting guidance is appreciated (should I try to use STM32CubeProgrammer to flash an alternative application code?).
I notice that if I create conditions that keep my application active (e.g. RAK3172 awake), I can upload a new program.
Question: could UART2 of the RAK3172 be disabled (RUI 4.2.2) by the combination of LPMLVL=2 and using api.system.sleep.all() in a function call by my loop()?
