Hi, hoping someone can get me on the right track here.
I’ve a Raspberry Pi 3B+ and PiSupply (RAK2247) Hat. I’ve set up the Chirpstack Gateway OS (4.2.0 Full) and configured Concentratored to SX1301:
It seems like the concentrator is not starting and is stuck in a loop:
Thu Jan 4 17:46:49 2024 user.info chirpstack-concentratord-sx1301[4061]: Starting the concentrator Thu Jan 4 17:46:54 2024 user.info chirpstack-concentratord-sx1301[4085]: Configuring reset pin, dev: /dev/gpiochip0, pin: 22 Thu Jan 4 17:46:54 2024 user.info chirpstack-concentratord-sx1301[4085]: Starting Concentratord SX1301 (version: 4.3.0, docs: www.chirpstack.io/docs/chirpstack-concentratord/) Thu Jan 4 17:46:54 2024 user.info chirpstack-concentratord-sx1301[4085]: Triggering sx1302 reset Thu Jan 4 17:46:54 2024 user.info chirpstack-concentratord-sx1301[4085]: Setting spi device path, spidev_path: /dev/spidev0.0 Thu Jan 4 17:46:54 2024 user.info chirpstack-concentratord-sx1301[4085]: Setting board configuration, lorawan_public: true, clock_source: 1 Thu Jan 4 17:46:54 2024 user.info chirpstack-concentratord-sx1301[4085]: Setting up concentrator radios Thu Jan 4 17:46:54 2024 user.info chirpstack-concentratord-sx1301[4085]: Configuring radio, radio: 0, enabled: true, center_freq: 867500000, type: SX1257 Thu Jan 4 17:46:54 2024 user.info chirpstack-concentratord-sx1301[4085]: Configuring radio, radio: 1, enabled: true, center_freq: 868500000, type: SX1257 Thu Jan 4 17:46:54 2024 user.info chirpstack-concentratord-sx1301[4085]: Setting up concentrator channels Thu Jan 4 17:46:54 2024 user.info chirpstack-concentratord-sx1301[4085]: Configuring multi-SF LoRa channel, channel: 0, enabled: true, freq: 868100000, rf_chain: 1, if_freq: -400000 Thu Jan 4 17:46:54 2024 user.info chirpstack-concentratord-sx1301[4085]: Configuring multi-SF LoRa channel, channel: 1, enabled: true, freq: 868300000, rf_chain: 1, if_freq: -200000 Thu Jan 4 17:46:54 2024 user.info chirpstack-concentratord-sx1301[4085]: Configuring multi-SF LoRa channel, channel: 2, enabled: true, freq: 868500000, rf_chain: 1, if_freq: 0 Thu Jan 4 17:46:54 2024 user.info chirpstack-concentratord-sx1301[4085]: Configuring multi-SF LoRa channel, channel: 3, enabled: true, freq: 867100000, rf_chain: 0, if_freq: -400000 Thu Jan 4 17:46:54 2024 user.info chirpstack-concentratord-sx1301[4085]: Configuring multi-SF LoRa channel, channel: 4, enabled: true, freq: 867300000, rf_chain: 0, if_freq: -200000 Thu Jan 4 17:46:54 2024 user.info chirpstack-concentratord-sx1301[4085]: Configuring multi-SF LoRa channel, channel: 5, enabled: true, freq: 867500000, rf_chain: 0, if_freq: 0 Thu Jan 4 17:46:54 2024 user.info chirpstack-concentratord-sx1301[4085]: Configuring multi-SF LoRa channel, channel: 6, enabled: true, freq: 867700000, rf_chain: 0, if_freq: 200000 Thu Jan 4 17:46:54 2024 user.info chirpstack-concentratord-sx1301[4085]: Configuring multi-SF LoRa channel, channel: 7, enabled: true, freq: 867900000, rf_chain: 0, if_freq: 400000 Thu Jan 4 17:46:54 2024 user.info chirpstack-concentratord-sx1301[4085]: Configuring Std LoRa channel, enabled: true, freq: 868300000, rf_chain: 1, if_freq: -200000 Thu Jan 4 17:46:54 2024 user.info chirpstack-concentratord-sx1301[4085]: Configuring FSK channel, enabled: true, freq: 868800000, rf_chain: 1, if_freq: 300000 Thu Jan 4 17:46:54 2024 user.info chirpstack-concentratord-sx1301[4085]: Starting the concentrator Thu Jan 4 17:46:59 2024 user.info chirpstack-concentratord-sx1301[4122]: Configuring reset pin, dev: /dev/gpiochip0, pin: 22 Thu Jan 4 17:46:59 2024 user.info chirpstack-concentratord-sx1301[4122]: Starting Concentratord SX1301 (version: 4.3.0, docs: www.chirpstack.io/docs/chirpstack-concentratord/) Thu Jan 4 17:46:59 2024 user.info chirpstack-concentratord-sx1301[4122]: Triggering sx1302 reset Thu Jan 4 17:47:00 2024 user.info chirpstack-concentratord-sx1301[4122]: Setting spi device path, spidev_path: /dev/spidev0.0 Thu Jan 4 17:47:00 2024 user.info chirpstack-concentratord-sx1301[4122]: Setting board configuration, lorawan_public: true, clock_source: 1 Thu Jan 4 17:47:00 2024 user.info chirpstack-concentratord-sx1301[4122]: Setting up concentrator radios Thu Jan 4 17:47:00 2024 user.info chirpstack-concentratord-sx1301[4122]: Configuring radio, radio: 0, enabled: true, center_freq: 867500000, type: SX1257 Thu Jan 4 17:47:00 2024 user.info chirpstack-concentratord-sx1301[4122]: Configuring radio, radio: 1, enabled: true, center_freq: 868500000, type: SX1257 Thu Jan 4 17:47:00 2024 user.info chirpstack-concentratord-sx1301[4122]: Setting up concentrator channels Thu Jan 4 17:47:00 2024 user.info chirpstack-concentratord-sx1301[4122]: Configuring multi-SF LoRa channel, channel: 0, enabled: true, freq: 868100000, rf_chain: 1, if_freq: -400000 Thu Jan 4 17:47:00 2024 user.info chirpstack-concentratord-sx1301[4122]: Configuring multi-SF LoRa channel, channel: 1, enabled: true, freq: 868300000, rf_chain: 1, if_freq: -200000 Thu Jan 4 17:47:00 2024 user.info chirpstack-concentratord-sx1301[4122]: Configuring multi-SF LoRa channel, channel: 2, enabled: true, freq: 868500000, rf_chain: 1, if_freq: 0 Thu Jan 4 17:47:00 2024 user.info chirpstack-concentratord-sx1301[4122]: Configuring multi-SF LoRa channel, channel: 3, enabled: true, freq: 867100000, rf_chain: 0, if_freq: -400000 Thu Jan 4 17:47:00 2024 user.info chirpstack-concentratord-sx1301[4122]: Configuring multi-SF LoRa channel, channel: 4, enabled: true, freq: 867300000, rf_chain: 0, if_freq: -200000 Thu Jan 4 17:47:00 2024 user.info chirpstack-concentratord-sx1301[4122]: Configuring multi-SF LoRa channel, channel: 5, enabled: true, freq: 867500000, rf_chain: 0, if_freq: 0 Thu Jan 4 17:47:00 2024 user.info chirpstack-concentratord-sx1301[4122]: Configuring multi-SF LoRa channel, channel: 6, enabled: true, freq: 867700000, rf_chain: 0, if_freq: 200000 Thu Jan 4 17:47:00 2024 user.info chirpstack-concentratord-sx1301[4122]: Configuring multi-SF LoRa channel, channel: 7, enabled: true, freq: 867900000, rf_chain: 0, if_freq: 400000 Thu Jan 4 17:47:00 2024 user.info chirpstack-concentratord-sx1301[4122]: Configuring Std LoRa channel, enabled: true, freq: 868300000, rf_chain: 1, if_freq: -200000 Thu Jan 4 17:47:00 2024 user.info chirpstack-concentratord-sx1301[4122]: Configuring FSK channel, enabled: true, freq: 868800000, rf_chain: 1, if_freq: 300000 Thu Jan 4 17:47:00 2024 user.info chirpstack-concentratord-sx1301[4122]: Starting the concentrator Thu Jan 4 17:47:05 2024 user.info chirpstack-concentratord-sx1301[4129]: Configuring reset pin, dev: /dev/gpiochip0, pin: 22 Thu Jan 4 17:47:05 2024 user.info chirpstack-concentratord-sx1301[4129]: Starting Concentratord SX1301 (version: 4.3.0, docs: www.chirpstack.io/docs/chirpstack-concentratord/) Thu Jan 4 17:47:05 2024 user.info chirpstack-concentratord-sx1301[4129]: Triggering sx1302 reset Thu Jan 4 17:47:05 2024 user.info chirpstack-concentratord-sx1301[4129]: Setting spi device path, spidev_path: /dev/spidev0.0 Thu Jan 4 17:47:05 2024 user.info chirpstack-concentratord-sx1301[4129]: Setting board configuration, lorawan_public: true, clock_source: 1 Thu Jan 4 17:47:05 2024 user.info chirpstack-concentratord-sx1301[4129]: Setting up concentrator radios Thu Jan 4 17:47:05 2024 user.info chirpstack-concentratord-sx1301[4129]: Configuring radio, radio: 0, enabled: true, center_freq: 867500000, type: SX1257 Thu Jan 4 17:47:05 2024 user.info chirpstack-concentratord-sx1301[4129]: Configuring radio, radio: 1, enabled: true, center_freq: 868500000, type: SX1257 Thu Jan 4 17:47:05 2024 user.info chirpstack-concentratord-sx1301[4129]: Setting up concentrator channels Thu Jan 4 17:47:05 2024 user.info chirpstack-concentratord-sx1301[4129]: Configuring multi-SF LoRa channel, channel: 0, enabled: true, freq: 868100000, rf_chain: 1, if_freq: -400000 Thu Jan 4 17:47:05 2024 user.info chirpstack-concentratord-sx1301[4129]: Configuring multi-SF LoRa channel, channel: 1, enabled: true, freq: 868300000, rf_chain: 1, if_freq: -200000 Thu Jan 4 17:47:05 2024 user.info chirpstack-concentratord-sx1301[4129]: Configuring multi-SF LoRa channel, channel: 2, enabled: true, freq: 868500000, rf_chain: 1, if_freq: 0 Thu Jan 4 17:47:05 2024 user.info chirpstack-concentratord-sx1301[4129]: Configuring multi-SF LoRa channel, channel: 3, enabled: true, freq: 867100000, rf_chain: 0, if_freq: -400000 Thu Jan 4 17:47:05 2024 user.info chirpstack-concentratord-sx1301[4129]: Configuring multi-SF LoRa channel, channel: 4, enabled: true, freq: 867300000, rf_chain: 0, if_freq: -200000 Thu Jan 4 17:47:05 2024 user.info chirpstack-concentratord-sx1301[4129]: Configuring multi-SF LoRa channel, channel: 5, enabled: true, freq: 867500000, rf_chain: 0, if_freq: 0 Thu Jan 4 17:47:05 2024 user.info chirpstack-concentratord-sx1301[4129]: Configuring multi-SF LoRa channel, channel: 6, enabled: true, freq: 867700000, rf_chain: 0, if_freq: 200000 Thu Jan 4 17:47:05 2024 user.info chirpstack-concentratord-sx1301[4129]: Configuring multi-SF LoRa channel, channel: 7, enabled: true, freq: 867900000, rf_chain: 0, if_freq: 400000 Thu Jan 4 17:47:05 2024 user.info chirpstack-concentratord-sx1301[4129]: Configuring Std LoRa channel, enabled: true, freq: 868300000, rf_chain: 1, if_freq: -200000 Thu Jan 4 17:47:05 2024 user.info chirpstack-concentratord-sx1301[4129]: Configuring FSK channel, enabled: true, freq: 868800000, rf_chain: 1, if_freq: 300000 Thu Jan 4 17:47:05 2024 user.info chirpstack-concentratord-sx1301[4129]: Starting the concentrator Thu Jan 4 17:47:10 2024 user.info chirpstack-concentratord-sx1301[4134]: Configuring reset pin, dev: /dev/gpiochip0, pin: 22 Thu Jan 4 17:47:10 2024 user.info chirpstack-concentratord-sx1301[4134]: Starting Concentratord SX1301 (version: 4.3.0, docs: www.chirpstack.io/docs/chirpstack-concentratord/) Thu Jan 4 17:47:10 2024 user.info chirpstack-concentratord-sx1301[4134]: Triggering sx1302 reset Thu Jan 4 17:47:10 2024 user.info chirpstack-concentratord-sx1301[4134]: Setting spi device path, spidev_path: /dev/spidev0.0 Thu Jan 4 17:47:10 2024 user.info chirpstack-concentratord-sx1301[4134]: Setting board configuration, lorawan_public: true, clock_source: 1 Thu Jan 4 17:47:10 2024 user.info chirpstack-concentratord-sx1301[4134]: Setting up concentrator radios Thu Jan 4 17:47:10 2024 user.info chirpstack-concentratord-sx1301[4134]: Configuring radio, radio: 0, enabled: true, center_freq: 867500000, type: SX1257 Thu Jan 4 17:47:10 2024 user.info chirpstack-concentratord-sx1301[4134]: Configuring radio, radio: 1, enabled: true, center_freq: 868500000, type: SX1257 Thu Jan 4 17:47:10 2024 user.info chirpstack-concentratord-sx1301[4134]: Setting up concentrator channels Thu Jan 4 17:47:10 2024 user.info chirpstack-concentratord-sx1301[4134]: Configuring multi-SF LoRa channel, channel: 0, enabled: true, freq: 868100000, rf_chain: 1, if_freq: -400000 Thu Jan 4 17:47:10 2024 user.info chirpstack-concentratord-sx1301[4134]: Configuring multi-SF LoRa channel, channel: 1, enabled: true, freq: 868300000, rf_chain: 1, if_freq: -200000 Thu Jan 4 17:47:10 2024 user.info chirpstack-concentratord-sx1301[4134]: Configuring multi-SF LoRa channel, channel: 2, enabled: true, freq: 868500000, rf_chain: 1, if_freq: 0 Thu Jan 4 17:47:10 2024 user.info chirpstack-concentratord-sx1301[4134]: Configuring multi-SF LoRa channel, channel: 3, enabled: true, freq: 867100000, rf_chain: 0, if_freq: -400000 Thu Jan 4 17:47:10 2024 user.info chirpstack-concentratord-sx1301[4134]: Configuring multi-SF LoRa channel, channel: 4, enabled: true, freq: 867300000, rf_chain: 0, if_freq: -200000 Thu Jan 4 17:47:10 2024 user.info chirpstack-concentratord-sx1301[4134]: Configuring multi-SF LoRa channel, channel: 5, enabled: true, freq: 867500000, rf_chain: 0, if_freq: 0 Thu Jan 4 17:47:10 2024 user.info chirpstack-concentratord-sx1301[4134]: Configuring multi-SF LoRa channel, channel: 6, enabled: true, freq: 867700000, rf_chain: 0, if_freq: 200000 Thu Jan 4 17:47:10 2024 user.info chirpstack-concentratord-sx1301[4134]: Configuring multi-SF LoRa channel, channel: 7, enabled: true, freq: 867900000, rf_chain: 0, if_freq: 400000 Thu Jan 4 17:47:10 2024 user.info chirpstack-concentratord-sx1301[4134]: Configuring Std LoRa channel, enabled: true, freq: 868300000, rf_chain: 1, if_freq: -200000 Thu Jan 4 17:47:10 2024 user.info chirpstack-concentratord-sx1301[4134]: Configuring FSK channel, enabled: true, freq: 868800000, rf_chain: 1, if_freq: 300000 Thu Jan 4 17:47:10 2024 user.info chirpstack-concentratord-sx1301[4134]: Starting the concentrator Thu Jan 4 17:47:15 2024 user.info chirpstack-concentratord-sx1301[4139]: Configuring reset pin, dev: /dev/gpiochip0, pin: 22 Thu Jan 4 17:47:15 2024 user.info chirpstack-concentratord-sx1301[4139]: Starting Concentratord SX1301 (version: 4.3.0, docs: www.chirpstack.io/docs/chirpstack-concentratord/) Thu Jan 4 17:47:15 2024 user.info chirpstack-concentratord-sx1301[4139]: Triggering sx1302 reset Thu Jan 4 17:47:15 2024 user.info chirpstack-concentratord-sx1301[4139]: Setting spi device path, spidev_path: /dev/spidev0.0 Thu Jan 4 17:47:15 2024 user.info chirpstack-concentratord-sx1301[4139]: Setting board configuration, lorawan_public: true, clock_source: 1 Thu Jan 4 17:47:15 2024 user.info chirpstack-concentratord-sx1301[4139]: Setting up concentrator radios Thu Jan 4 17:47:15 2024 user.info chirpstack-concentratord-sx1301[4139]: Configuring radio, radio: 0, enabled: true, center_freq: 867500000, type: SX1257 Thu Jan 4 17:47:15 2024 user.info chirpstack-concentratord-sx1301[4139]: Configuring radio, radio: 1, enabled: true, center_freq: 868500000, type: SX1257 Thu Jan 4 17:47:15 2024 user.info chirpstack-concentratord-sx1301[4139]: Setting up concentrator channels Thu Jan 4 17:47:15 2024 user.info chirpstack-concentratord-sx1301[4139]: Configuring multi-SF LoRa channel, channel: 0, enabled: true, freq: 868100000, rf_chain: 1, if_freq: -400000 Thu Jan 4 17:47:15 2024 user.info chirpstack-concentratord-sx1301[4139]: Configuring multi-SF LoRa channel, channel: 1, enabled: true, freq: 868300000, rf_chain: 1, if_freq: -200000 Thu Jan 4 17:47:15 2024 user.info chirpstack-concentratord-sx1301[4139]: Configuring multi-SF LoRa channel, channel: 2, enabled: true, freq: 868500000, rf_chain: 1, if_freq: 0 Thu Jan 4 17:47:15 2024 user.info chirpstack-concentratord-sx1301[4139]: Configuring multi-SF LoRa channel, channel: 3, enabled: true, freq: 867100000, rf_chain: 0, if_freq: -400000 Thu Jan 4 17:47:15 2024 user.info chirpstack-concentratord-sx1301[4139]: Configuring multi-SF LoRa channel, channel: 4, enabled: true, freq: 867300000, rf_chain: 0, if_freq: -200000 Thu Jan 4 17:47:15 2024 user.info chirpstack-concentratord-sx1301[4139]: Configuring multi-SF LoRa channel, channel: 5, enabled: true, freq: 867500000, rf_chain: 0, if_freq: 0 Thu Jan 4 17:47:15 2024 user.info chirpstack-concentratord-sx1301[4139]: Configuring multi-SF LoRa channel, channel: 6, enabled: true, freq: 867700000, rf_chain: 0, if_freq: 200000 Thu Jan 4 17:47:15 2024 user.info chirpstack-concentratord-sx1301[4139]: Configuring multi-SF LoRa channel, channel: 7, enabled: true, freq: 867900000, rf_chain: 0, if_freq: 400000 Thu Jan 4 17:47:15 2024 user.info chirpstack-concentratord-sx1301[4139]: Configuring Std LoRa channel, enabled: true, freq: 868300000, rf_chain: 1, if_freq: -200000 Thu Jan 4 17:47:15 2024 user.info chirpstack-concentratord-sx1301[4139]: Configuring FSK channel, enabled: true, freq: 868800000, rf_chain: 1, if_freq: 300000
Hopefully someone can point me in the right direction …?
) hence the paste.
