So I finally managed converting from 4631 R to the regular version (because I want to use meshtastic), and through trial and tribulations I managed to do so with the nrfutil method. So after this method it rebooted, and it could be seen as a usb drive and it had the regular " CURRENT.UF2, INDEX.HTM, and INFO_UF2.TXT" inside of it. The instruction was to get the latest release which is the “firmware-rak4631-2.2.14.57542ce.uf2” and put it inside, so I did, it reboots, but upon reboot there is no connectivity with Bluetooth.
If I try to reach it through CLI or Tera term I only get timeouts. After a reboot of my pc, its timeouts, before that I get a port blocked warning. So no bluetooth. Cannot reach it with CLI. Tera Term also timesout. I have no idea what I am doing wrong. The “meshtastic --info” also time out. But at least the double click and usb visiblity works now.
The last firmware I put in was the factory erase. After that it just acted like it did now. Meshtastic --noproto also times out
Did I just brick it?
C:\Users\Anon\Desktop\rak conversion>meshtastic --info
File “”, line 198, in run_module_as_main
File “”, line 88, in run_code
File "C:\Program Files\Python311\Scripts\meshtastic.exe_main.py", line 7, in
File "C:\Users\Anon\AppData\Roaming\Python\Python311\site-packages\meshtastic_main.py", line 1351, in main
common()
File “C:\Users\Anon\AppData\Roaming\Python\Python311\site-packages\meshtastic_main_.py”, line 953, in common
client = meshtastic.serial_interface.SerialInterface(
File “C:\Users\Anon\AppData\Roaming\Python\Python311\site-packages\meshtastic\serial_interface.py”, line 61, in init
StreamInterface.init(
File “C:\Users\Anon\AppData\Roaming\Python\Python311\site-packages\meshtastic\stream_interface.py”, line 50, in init
self.connect()
File “C:\Users\Anon\AppData\Roaming\Python\Python311\site-packages\meshtastic\stream_interface.py”, line 74, in connect
self._waitConnected()
File “C:\Users\Anon\AppData\Roaming\Python\Python311\site-packages\meshtastic\mesh_interface.py”, line 599, in _waitConnected
raise Exception(“Timed out waiting for connection completion”)
Exception: Timed out waiting for connection completion
fun fact, just to get here took me 5 hours through many different methods, I am so tired
