Hi carlrowan,
below is my Arduino code with the I/O ports PB2 and BB12. These stay at about 1.8 V and don’t change with digitalWrite.
How can I get the firmware version? The command AT+VERSION from your RAK_SERIAL_PORT_TOOL_V1.2.1 is not supported.
Jan
uint8_t LEDW1 = PA0; /yellow LED bank 1/
uint8_t LEDW2 = PA1; /yellow LED bank 2/
uint8_t LEDA1 = PA8; /red LED bank 1/
uint8_t LEDA2 = PA9; /red LED bank 2/
uint8_t LEDR = PB2; /RGB LED red/
uint8_t LEDG = PB12; /RGB LED green/
uint8_t LEDB = PB5; /RGB LED blue/
uint8_t Addr1 = PA7; /address switch output 2^0/
uint8_t Addr2 = PA6; /address switch output 2^1/
uint8_t Addr4 = PA5; /address switch output 2^2/
uint8_t Addr8 = PA4; /address switch output 2^3/
uint8_t ADC1 = WB_A1; /ADC input for supply voltage/
long startTime;
double myFreq = 868000000;
uint16_t sf = 12, bw = 0, cr = 0, preamble = 8, txPower = 22;
uint8_t Status;
uint16_t Timer;
uint8_t Address;
uint8_t Address1;
#define Timeout 100
#define BattMin 310
bool RxDone = false;
void recv_cb(rui_lora_p2p_recv_t data) /Rx callback/
RxDone = true;
char Buff[92];
sprintf(Buff, “Incoming message, length: %d, RSSI: %d, SNR: %d, %s\n”, data.BufferSize, data.Rssi, data.Snr, data.Buffer);
Serial.println(Buff); /send Rx confirmation via UART/
if (data.Buffer[0] == ‘#’)
Address1 = data.Buffer[1] - 48;
if (Address1 > 9) /for hex numbers A to F/
Address1 -= 7;
if (Address == Address1)
if ((data.Buffer[2] == ‘0’) && (Timer > Timeout)) /no warning/alarm/
Status = 1;
else if ((data.Buffer[2] == ‘W’) && (Timer > Timeout)) /warning/
Status = 2;
else if (data.Buffer[2] == ‘A’) /alarm/
Status = 3;
else
Status = 0;
void send_cb(void) /Tx callback/
Serial.printf(“P2P set Rx mode %s\r\n”, api.lorawan.precv(65534) ? “OK” : “ERROR”); /send Tx status via UART and return to Rx/
void setup()
// initialize serial communication at 115200 bits per second
Serial.println(“VM40-R2 Initialization”);
// initialize the LED pins as an output
pinMode(LEDW1, OUTPUT);
pinMode(LEDW2, OUTPUT);
pinMode(LEDA1, OUTPUT);
pinMode(LEDA2, OUTPUT);
pinMode(LEDR, OUTPUT);
pinMode(LEDG, OUTPUT);
pinMode(LEDB, OUTPUT);
digitalWrite(LEDR, HIGH);
digitalWrite(LEDG, LOW); /green status LED on/
digitalWrite(LEDB, HIGH);
pinMode(Addr1, INPUT_PULLUP);
pinMode(Addr2, INPUT_PULLUP);
pinMode(Addr4, INPUT_PULLUP);
pinMode(Addr8, INPUT_PULLUP);
startTime = millis();
Serial.println(“P2P Start”);
Serial.printf(“Hardware ID: %s\r\n”, api.system.chipId.get().c_str());
Serial.printf(“Model ID: %s\r\n”, api.system.modelId.get().c_str());
Serial.printf(“RUI API Version: %s\r\n”, api.system.apiVersion.get().c_str());
Serial.printf(“Firmware Version: %s\r\n”, api.system.firmwareVersion.get().c_str());
Serial.printf(“AT Command Version: %s\r\n”, api.system.cliVersion.get().c_str());
Serial.printf(“Set Node device work mode %s\r\n”, api.lorawan.nwm.set(0) ? “OK” : “ERROR”);
Serial.printf(“Set P2P mode frequency %3.3f: %s\r\n”, (myFreq / 1e6), api.lorawan.pfreq.set(myFreq) ? “OK” : “ERROR”);
Serial.printf(“Set P2P mode spreading factor %d: %s\r\n”, sf, api.lorawan.psf.set(sf) ? “OK” : “ERROR”);
Serial.printf(“Set P2P mode bandwidth %d: %s\r\n”, bw, api.lorawan.pbw.set(bw) ? “OK” : “ERROR”);
Serial.printf(“Set P2P mode code rate 4/%d: %s\r\n”, (cr + 5), api.lorawan.pcr.set(0) ? “OK” : “ERROR”);
Serial.printf(“Set P2P mode preamble length %d: %s\r\n”, preamble, api.lorawan.ppl.set(8) ? “OK” : “ERROR”);
Serial.printf(“Set P2P mode tx power %d: %s\r\n”, txPower, api.lorawan.ptp.set(22) ? “OK” : “ERROR”);
api.lorawan.registerPRecvCallback(recv_cb);
api.lorawan.registerPSendCallback(send_cb);
Timer = 0; /reset timeout/
void loop()
Address = 15 - (digitalRead(Addr1) + (digitalRead(Addr2) << 1) + (digitalRead(Addr4) << 2) + (digitalRead(Addr8) << 3)); /read out address switch/
int Batt = analogRead(ADC1);
if (Status == 1) /no warning/alarm/
digitalWrite(LEDW1, LOW); /all warning/alarm LEDs off/
digitalWrite(LEDW2, LOW);
digitalWrite(LEDA1, LOW);
digitalWrite(LEDA2, LOW);
else if (Status == 2) /warning/
digitalWrite(LEDW1, HIGH);
delay(100);
digitalWrite(LEDW2, HIGH);
else if (Status == 3) /alarm/
digitalWrite(LEDA1, HIGH);
delay(100);
digitalWrite(LEDA2, HIGH);
delay(100);
if (Batt < BattMin) /if battery empty/
digitalWrite(LEDG, HIGH);
digitalWrite(LEDB, LOW); /blue status LED on/
if (Status && RxDone) /after receiving a status message/
RxDone = false;
Timer = 0;
if (Batt >= BattMin) /if battery OK/
if (++Timer == Timeout)
Timer = Timeout + 1;
digitalWrite(LEDR, LOW); /red status LED on/
Status = 0;
