In this example, I see this piece of code: api.system.lpm.set(1);
However, in the api description, I don’t see it documented.
What am I missing ?
What am I missing ?
The documentation needs to be updated. It will be included soon.
Hello Bernd,
When you wrote “soon”, what kind of time reference did you have in mind ?
Should have been in the last doc update (a few weeks ago), but seems it is still missing.
api.system.lpm.get();
/**@par Description
* This api allows to get the low power mode
* @par Syntax
* api.system.lpm.get()
* @retval 1 for low power mode enabled
* @retval 0 for low power mode disabled
* @par Example
* @verbatim
void setup()
Serial.printf("Set the low power mode %s\n\r", api.system.lpm.set(1) ? "Success" : "Fail");
void loop()
Serial.printf("The low power mode = %d\n\r", api.system.lpm.get());
delay(1000);
@endverbatim
api.system.lpm.set();
/**@par Description
* This api allows to set the low power mode
* @par Syntax
* api.system.lpm.set(value)
* @note Only 0 or 1 is acceptable
* @param value 0 or 1
* @return bool
* @retval TRUE for setting low power mode success
* @retval FALSE for setting low power mode failure
* @par Example
* @verbatim
void setup()
void loop()
delay(1000);
@endverbatim
