Arduino on Rak5010!
Hi all.
Can you please tell me if the following procedure can be done?
  1. Get the last Adafruit feather_nrf52840_express_bootloader-0.3.2_s140_6.1.1.hex from https://github.com/adafruit/Adafruit_nRF52_Bootloader/releases/download/0.3.2/feather_nrf52840_express_bootloader-0.3.2_s140_6.1.1.hex
  2. Download it to the smartphone and burn it using BLE using “nRF Connect” as explained at:
    https://doc.rakwireless.com/rak5010-wistrio-nb-iot-tracker/upgrading-firmware-through-dfu-over-ble
  3. Use Arduino IDE to program the nRF as posted here.
DFU in step 2 is based on our RUI firmware. It can’t be mixed with Arduino because of two system. In fact, Arduino support DFU with Adafruit code and hex. If you want to do it, you can refer to the this. But remember, the board must have firmware support DFU. If empty, nothing can be done.
#include <Arduino.h>
#include <bluefruit.h>
// Forward declarations for functions
void connect_callback(uint16_t conn_handle);
void disconnect_callback(uint16_t conn_handle, uint8_t reason);
@brief BLE DFU service
@note Used for DFU OTA upgrade
BLEDfu bledfu;
@brief Arduino setup function. Called once after power on or reset
// Initialize built in green LED
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, HIGH);
// Initialize Serial for debug output
// Wait for USB Serial to be ready or terminal to be connected
time_t timeout = millis(); // Timeout in case the system runs on its own
// Waiting for Serial
while (!Serial)
if ((millis() - timeout) < 5000)
// Blink the LED to show that we are alive
delay(100);
digitalWrite(LED_BUILTIN, !digitalRead(LED_BUILTIN));
// Timeout while waiting for USB Serial
// Config the peripheral connection with maximum bandwidth
// more SRAM required by SoftDevice
// Note: All config***() function must be called before begin()
Bluefruit.configPrphBandwidth(BANDWIDTH_MAX);
Bluefruit.configPrphConn(92, BLE_GAP_EVENT_LENGTH_MIN, 16, 16);
Bluefruit.begin(1, 0);
// Set max power. Accepted values are: -40, -30, -20, -16, -12, -8, -4, 0, 4
Bluefruit.setTxPower(4);
// Set the BLE device name
Bluefruit.setName(“RAK4631_OTA”);
Bluefruit.Periph.setConnectCallback(connect_callback);
Bluefruit.Periph.setDisconnectCallback(disconnect_callback);
// To be consistent OTA DFU should be added first if it exists
bledfu.begin();
// Set up and start advertising
// Advertising packet
Bluefruit.Advertising.addFlags(BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE);
Bluefruit.Advertising.addTxPower();
Bluefruit.Advertising.addName();
/* Start Advertising
- Enable auto advertising if disconnected
- Interval: fast mode = 20 ms, slow mode = 152.5 ms
- Timeout for fast mode is 30 seconds
- Start(timeout) with timeout = 0 will advertise forever (until connected)
 For recommended advertising interval
 https://developer.apple.com/library/content/qa/qa1931/_index.html
Bluefruit.Advertising.restartOnDisconnect(true);
Bluefruit.Advertising.setInterval(32, 244); // in unit of 0.625 ms
Bluefruit.Advertising.setFastTimeout(30); // number of seconds in fast mode
Bluefruit.Advertising.start(0); // 0 = Don’t stop advertising after n seconds
@brief Callback when client connects
@param conn_handle: Connection handle id
(void)conn_handle;
Serial.println(“BLE client connected”);
@brief Callback invoked when a connection is dropped
@param conn_handle: connection handle id
@param reason: disconnect reason
(void)conn_handle;
(void)reason;
Serial.println(“BLE client disconnected”);
@brief Arduino loop. Runs forever until power off or reset
Thanks Nero!.
In fact, my target is to use Arduino IDE to make my own code and burn/upload it using the USB connection to the computer.
Is there a way to reach this, without using Jlink (as stablished on 8 of first post)?
I have a new rak5010.
No matter what IDE, the board must have the initial hex. Empty flash can do nothing. Jlink or DAP link is necessary.
So. With initial hex can I flash the arduino hex using BLE?
And then use USB for next hex?
Yes. You need a application and DFU file. You can refer to
Install it and refer to the bluefruit ble example. They provide the example of DFU.
Hi Nero.
I tried the procedure but aborted in the final step of flashing using DFU, because the confirmation popup asked for a *.dat file when trying to upload a hex file.
Let me try to clarify the situation.
I DO NOT have a Jlink programmer.
The rak5010 board is new, so it has the original .hex.
I want to burn the feather express bootloader as first step so in next steps I can program using serial port directly from Arduino IDE. (Is this correct?)
Sorry for the inconveniences. Not english speaker, and I don’t want to do something irreversible.
Can you (or anyone) detail how to?
Regards.
Ramiro
The original hex is suitable for RUI. RUI is different from Arduino. Means you can’t OTA other bootloader or application to the board. Because it is cryptographic during OTA. One bootloader corresponding one application and one DFU zip. If you want to use other bootloader, you must use a programmer like Jlink or DAP-link. Or you can use our RUI compile system. It will supply the DFU zip, HEX. Our firmware can’t guarantee non-RUI hex or DFU.
So without jlink is imposible to burn arduino bootloader?
Right. DAP link works too.
OK. Any suggestion or steps to follow to use DAP link?
I really need to start programming in Arduino the nRF.
Thank you again @nero
For now, our DAP-LINK is not in store. The Jlink is best. Details as below:
https://doc.rakwireless.com/rak5010-wistrio-nb-iot-tracker/burning-the-firmware
I really don’t understand. You suggest me dap-link and then sent me to jlink. Really confused.
Also JTAG link in your store is broken…
https://store.rakwireless.com/products/emulator-kit
Our DAP-Link is not yet on the market. About next month. The guide will release together.
Hi @nero. Back again!
Finally I could flash the bootloader using a Raspberry PI and openocd.
Then, using Rak5010.rui from github, everything goes ok, compiling and flashing.
The problem I’m facing, is only receiving the:
****************************** Arduino on Rak5010 ******************************
bg96 power up!
message in serial terminal, and nothing else.
Could you tell me where to look?
Compiling with no errors, also when flashing. Following the steps as this post indicates.
Thanks again!
Ramiro
Do you modify the example code? After it starts up, it will power bg96 and scan all sensors on the boards. It looks like you are stuck here. If bg96 starts ok, the blue led on and red blink. Is it ok on your board? If ok, next to check sensors. In the setup(), you can delete sensors init one by one to find which sensor is not ok. It is important to exclude hardware problems.
Didn’t modify the code.
None of the leds (blue nor red) turns on or blink.
Only if I press BG PWRKEY button, leds behave as you described.
Seems a bg96_init routine problem.
Using the original firmware and AT commands, everything went correct.
OK, I see. Because the power up step is same as power off on bg96. So after download, you’d better remove the usb and insert again. And then open serial tool.
Already tryied that. downoad-> remove USB -> Insert USB -> open serial.
Same results
Hi Nero. Finally I found a problem in PCA1006 variant file. Serial1 wasn’t declared properly.
With Raspberry Pi, could flash, and reflash correctly. Then using Arduino IDE to burn new firmware’s.
Thanks you very much.
Ramiro
