according to the Quick Start Guide and the AT Command Manual the AT+P2P command should have the bandwidth in kHz as a number in it, like: AT+P2P=868000000:7:125:0:10:14 for 125 kHz.
However, this command produces an AT_PARAM_ERROR.
When I send AT+P2P=868000000:7:0:0:10:14 instead, the result is OK.
Is the bandwidth to be entered as index (0, 1, 2…) or what could be the mistake?
There was change on the latest firmware of the version on the parameters of bandwidth. However, we will make the bandwidth parameter backward compatible on the next release of RUI3.
I already answered this question in this forum thread. You can use it as reference.
