OK. ATC+STATUS was what i needed.
It shows that my band and subband are wrong.
I have used, AT+BAND=5 multiple times.
When i run AT+BAND? it returns 5
while looking thru the tracker code, i found at section in blues.cpp that also sets the band based on the country returned but notecard gps. It didnt handle Canada. I added code to the US915 to handle CA.
I can see it returning in the debug log before joining. But ATC+STATUS still show EU868 after failed join.
code added to blues.cpp
else if (strcmp(str_value, "US") == 0 || (strcmp(str_value, "CA") == 0))
MYLOG("BLUES", "Found US/CA");
boot log 1
failed join, status check, reset band, check band, reboot
[APP] init_app
WisBlock Blues Tracker
FW Ver 1.0.2
[USR_AT] Added 11 User AT commands
+EVT:RAK1906
+EVT:IMSI-864475046aaaaaa
[USR_AT] Valid Blues settings found, Blues Product UID = com.sixthsenseprocessware.craven:rak
[USR_AT] Selected SIM card: internal only
[BLUES] Found saved settings, override NoteCard internal settings!
[BLUES] Set Product ID and connection mode
[BLUES] Set SIM and APN
[BLUES] Set location mode off
[BLUES] Disable ATTN
[BLUES] Enable ATTN on motion
[BLUES] card.attn mode returned: {"set":true}
[BLUES] Arm ATTN on motion
[BLUES] Attach interrupt on motion
+EVT:RAK13102
[APP] restart_advertising
[APP] api_timer_start
[APP] Timer wakeup, start GNSS
[APP] GNSS inactive, start it
[BLUES] Set location mode continuous
[BLUES] Enable ATTN on location
[BLUES] Arm ATTN on location
[BLUES] Attach interrupt on location
[APP] ATTN triggered
[BLUES] card.attn mode returned: {"files":["location"],"set":true}
[BLUES] card.attn check returned: {"files":["location"],"set":true}
[BLUES] card.attn files: location
[BLUES] card.attn for LOCATION
[APP] GNSS wait finished
[BLUES] gnss_status >>GPS updated (32 sec, 38/38 dB SNR, 6/10 sats, HDOP 1.30) {gps-active} {gps-signal} {gps-sats} {gps}<<
[BLUES] GNSS is updated!
[BLUES] Got location Lat 43.585625 Long -79.607628
[BLUES] Last GNSS update was 1705156373
[BLUES] Found US/CA
[BLUES] Switch to band 5
[BLUES] Last card time was 1705156375
[BME] Start BME reading
[BME] RH= 34.91 T= 27.52 P= 973.890
[APP] Network not joined, skip sending over LoRaWAN
[APP] Get hub sync status:
[BLUES] Finished parsing
+EVT:TX_CELL_OK
[APP] Cellular count w/o Join 2
[APP] Join network failed
+EVT:JOIN_FAILED
Device status:
RAK4631
Mode LPWAN
Auto join enabled
Network not joined
LPWAN status:
Dev EUI xxxx09FFFE0Fxxxx
App EUI yyyyyyyyyyyyyyyy
App Key zzzzzzB55B098B37675A15CF11zzzzzz
Dev Addr 26021FB4
NWS Key 323D155A000DF335307A16D...............
Apps Key 3F6A66459D5EDCA63CBC46................
OTAA enabled
ADR enabled
Public Network
Dutycycle disabled
Join trials 3
TX Power 0
DR 3
Class 0
Subband 1
Fport 2
Unconfirmed Message
Region EU868
Send Frequency 3600
OK
OK
AT+BAND=5
OK
OK
AT+BAND=?
AT+BAND=5
OK
ATZ
after reboot
failed joined, check band, check status
[APP] init_app
FW Ver 1.0.2
+EVT:RAK1906
+EVT:RAK13102
[BLUES] gnss_status >>GPS updated (21 sec, 38/38 dB SNR, 5/6 sats, HDOP 1.50) {gps-active} {gps-signal} {gps-sats} {gps}<<
[BLUES] Got location Lat 43.585556 Long -79.607727
[BLUES] Last GNSS update was 1705156526
[BLUES] Found US/CA
[BLUES] Last card time was 1705156528
[BME] RH= 35.62 T= 27.16 P= 973.950
+EVT:TX_CELL_OK
+EVT:JOIN_FAILED
ATC+BAND=?
ATC+BAND=4
OK
Device status:
RAK4631
Mode LPWAN
Auto join enabled
Network not joined
LPWAN status:
Dev Addr 26021FB4
NWS Key 323D155A000DF335307A16DA.............
Apps Key 3F6A66459D5EDCA63CBC461..............
OTAA enabled
ADR enabled
Public Network
Dutycycle disabled
Join trials 3
TX Power 0
DR 3
Class 0
Subband 1
Fport 2
Unconfirmed Message
Region EU868
Send Frequency 3600
OK
OK
