BRICKED RAK4200
Issue:
DID A FIRMWARE Upgrade without putting module into boot mode, and it failed by timeout.
No AT command worked after that
Setup:
RAK4200 BREAKOUT MODULE
SERIAL PORT TOOL 1.2.1
RAK_Device_Firmware_Upgrade_Tool_v1.4
Server:
n/a
Details:
DID A FIRMWARE Upgrade without putting module into boot mode first, and it failed by timeout.
No AT command worked after that,
thus nothing can be done on it anymore. it is bricked
Needs to know how to revive it.
You’d need firmware that has not yet been published because releases aren’t in sync for the v1.4 tool to work.
So, you’ll need to use the current release on the downloads website.
I could tell you the secret command not documented anywhere to get a module out of boot loader mode, but then I’d have to kill you.
OK, don’t tell anyone, but it’s at+run
1, I was trying to download the right version , however the link is broken:
https://downloads.rakwireless.com/LoRa/Tools/RAK_Upgrade_Tool_V1.0.rar
2, at+run likes other at commands, returns nothing. I had made it clear in my the 1st post that it never entered boot loader mode. I did the upgrade while the board is running normally, and after the upgrade failed, I could still connect to the board via serial port, however no at command issued got any return
Er, no, you said you didn’t put it in to boot loader mode.
