On RUI3 Timer API, How do I call function by Timer API with an Integer value as a parameter?
I am using parameters in my RUI3-Signal-Meter-P2P-LPWAN
Start timer with parameter:
display_reason = 1;
api.system.timer.start(RAK_TIMER_1, 250, &display_reason);
Timer callback with parameter usage:
void handle_display(void *reason)
// Get the wakeup reason
uint8_t *disp_reason = (uint8_t *)reason;
// Check if we have a reason
if (disp_reason == NULL)
Serial.println("Bug in code!");
else if (disp_reason[0] == 1)
// RX event display
else if (disp_reason[0] == 2)
else if (disp_reason[0] == 3)
else if (disp_reason[0] == 5)
Thank you for your support.
I can start Timer API with parameter as you show me, but I wonder if it posible to start Timer API with a local variable as parameter? If yes, how can I do that?
I’ve try with this code, but it not work.
// uint8_t testValue = 1;
void testing(void *ch){
uint8_t *channel = (uint8_t*)ch;
if (channel[0] == NULL)
Serial.println("Testing");
} else {
Serial.printf("Testing with parameter: %d\r\n", channel[0]);
void setup()
Serial.println("Starting...");
api.system.timer.create(RAK_TIMER_0,(RAK_TIMER_HANDLER)testing, RAK_TIMER_PERIODIC);
testing(&testValue);
api.system.timer.start(RAK_TIMER_0, 1000, &testValue);
void loop()
api.system.sleep.all();
No it is not possible.
As you can see the parameter is given as a pointer to the parameter.
If you define the parameter local, it will be on the stack and destroyed when the function returns.
Many thanks for the clear explanation.
