I have a RAK3172 module that I want to run in class B. I am communicating through a RAK7258 gateway which connects to thethingsnetwork.com server. Connecting to the network and sending messages works fine but the gateway does not send beacon messages (which I have checked using SDR). The RAK3172 module displays an error “+BC:FAILED” indicating that no beacon message was received. Sending messages from the server (downlink) then does not work. What can I do to make my B-class device work properly?
Device parameters:
Module: “RAK3172-H Version:v1.0.2 May 26 2021”
Class B settings look like this:
OK
AT+PGSLOT=?
4
OK
AT+BFREQ=?
3,869.525
Gateway: RAK7258 with firmware “1.0.2_RAK rRAK-3940b904c", mode “Basic Station”, I did not find any more settings in the gateway that could affect beacon sending.
Regarding Class B, we still have pending issues with TTS and still being solved. RAK3172 Class B operation is working in the Network Server inside our WisGate Edge at the moment.
RAK4270 is based on RUI V2 which do not natively support class B. At the moment, we do not have any plan on implementing class B on RAK4270. If you have class B requirements, I highly encourage you to check RAK3172 as alternative. This will be a good choice specially if you are starting a new product design.
