Developing for the RAK3172 chipset in platformIO using Arduino
I’m interested in developing code for a weather station to run on the STM32W inside the RAK3172-T hardware. I built the PCB for this project without realizing that the code runs on top of the RUI interface. Since I’m using a custom LoRa implementation (FANET – protocol documentation), I need direct access to the radio.
Has anyone got tips for doing this within PlatformIO using the Arduino framework?
Many thanks,
Mike
RUI3 is not supported by PlatformIO.
But you can use Visual Studio Code with Arduino Extension.
Thank you, BeeGee, for your fast reply! My understanding is that I can’t use the RUI3 firmware because I need direct access to the LoRa chip, must develop directly for the STM32W? I’m taking a look at the Meshtastic implementation, as they seem to have solved this, although it’s not straightforward.
Afaik Meshtastic has no official support for the STM32LWE5.
I see it in their repo, but it is not officially released.
You might want to talk with them directly.
For STM32CubeIDE, it is possible to use. See our RAK3172 WisDuo LPWAN Module Low Level Development Reference
Thank you for your reply.
I’ve made some progress with my project, but I’m running into an issue with the LoRa signal strength. Even across a small room, the signal is exceptionally weak. I suspect the problem might be with the RF switch configuration, as changing its settings doesn’t seem to affect the signal strength at all.
I’d like to confirm that the two GPIO pins used for RF switching are PB8 and PC13. For reference, here’s the current code I’m using to define the RF switch:
cpp
CopyEdit
// RF switch configuration
// static const uint32_t rfswitch_pins[5] = {PA4, PA5, RADIOLIB_NC, RADIOLIB_NC, RADIOLIB_NC};
static const uint32_t rfswitch_pins[5] = {PB8, PC13, RADIOLIB_NC, RADIOLIB_NC, RADIOLIB_NC};
static const Module::RfSwitchMode_t rfswitch_table[] = {
    {STM32WLx::MODE_IDLE,  {LOW, LOW}},
    {STM32WLx::MODE_RX,    {HIGH, LOW}},
    {STM32WLx::MODE_TX_LP, {LOW, HIGH}},
    {STM32WLx::MODE_TX_HP, {LOW, HIGH}},
    END_OF_MODE_TABLE
Does this configuration look correct? I’ve compared the LOW/HIGH logic to the STM32Cube examples and tried to match them accordingly.
Any help or confirmation would be appreciated.
Best regards,
Mike
PB8 and PC13 are correct, but I am not sure about the RfSwitchMode table.
This is handled inside RUI3.
RAK3112 uses only the RFO_HP pin, the RFI_LP pin is not connected, so MODE_TX_LP does not exist.
We are interested in this as well, we would like to use RAK3172 with platformIO and RadioLib.
@nzmikec could you share your platform project setup for RAK3172?
We failed to get RadioLib working (using example STM32WLx_Receive_Blocking.ino) even with your rfswitch pins and rfswitch_table, we get
[STM32WL] Initializing ... failed, code -707
Hi @simplysoft
see my repo here, theres a custom board setup that should get you going.
This is based off what I could find in the Meshtastic firmware.
Let me know how you get on!
