Hi guys, I got an error while configuring RAK5205 to LoraServer. The command is at+join. Any help will be appreciated
Is device EUI and App EUI same?
hello!
We need to gradually find out what the problem is,
First you need to check that your loraserver is working properly on other nodes
Then you need to check that the three parameters you configured are the same as those on loraserver.
Did you follow the 6 chapters in the document?
6. How to connect with LoRaServer?
https://downloads.rakwireless.com.cn/cn/LoRa/WisTrio-LoRa-RAK5205/%E5%BA%94%E7%94%A8%E7%AC%94%E8%AE%B0/Get_Start_with_RAK5205_WisTrio.pdf
In the loraserver of raspberry pie, APP_EUI is configured arbitrarily, as long as it is properly formatted and does not affect the connection.
What version number is your RAK5205 using? Check it out with the command: at+version
When you send data, will you receive any response data in the gateway?
I am using 3.0.0.3.H version. But as per the above pictures is it configured correctly? .
Yes, your configuration is correct.
Can you tell me what frequency band your gateway and nodes are using? EU868, US915…
Gateway is configured with AU915
So you use the command
at+get_config=lora:channel
to check your configuration and send me the screenshot. Thank you
You need to join with RAK5205 and make sure your devices are equipped with antennas
The antennas are attached
Do I need to check this box?
at+get_config=lora:status
at+get_config=device:status
You try sending these two commands and see what response he gets.
You try to restart the gateway and wait a minute to restart the node again.
Edit: got it working by changing to EU868 at+set_config=lora:region:EU868
and back to AU915 at+set_config=lora:region:AU915
I have the same issue, the 5205 does not want to connect to my chirpstack (loraserver), I have other nodes (LoPy4) joining the server.
I don’t see anything in the logs of the packet forwarder when sending a at+join
command. it’s almost like its not transmitting?
OK.
==============LoRaWAN Status List================
Work Mode: LoRaWAN
Region: AU915
Send_interval: 600s
Auto send status: true.
Send_interval work at sleep
Join_mode: OTAA
DevEui: B3593192F4C0547F
AppEui: B3593192F4C0547F
AppKey: B99F4679FBBCF4C85254D6E547656BDD
Class: A
Joined Network:false
IsConfirm: true
AdrEnable: true
EnableRepeaterSupport: false
RX2_CHANNEL_FREQUENCY: 923300000, RX2_CHANNEL_DR:8
RX_WINDOW_DURATION: 3000ms
RECEIVE_DELAY_1: 1000ms
RECEIVE_DELAY_2: 2000ms
JOIN_ACCEPT_DELAY_1: 5000ms
JOIN_ACCEPT_DELAY_2: 6000ms
Current Datarate: 0
Primeval Datarate: 0
ChannelsTxPower: 0
UpLinkCounter: 0
DownLinkCounter: 0
OK.
===============Device Status List================
Board Core: RAK811
MCU: STM32L151CB_A
LoRa chip: SX1276
Battery Voltage:3.690 V
BME680 sensor data:
Humidity:41.762 %RH
Temperature:41.17 degree
Pressure:1007.14 hPa
Gas_resistance: 3269 ohms
>>at+version
OK3.0.0.11.H
Can you tell me what gateway you are using?
The gateway hardware EU868 of RAK2247 is different from that of US915. If you use the same hardware without switching, I guess this is the problem.
