Im using chirpstack v4 with rak2287, and im using rak3172 for end device. Rak3172 joined to network but it doesnt send any message, when i want to send message always i got this error evt:SEND_CONFIRMED_FAILED(4)
When I look at the gateway logs, I only see the join request and confirmation, I cannot see the messages I sent from the sent end device. I installed rak gateway for chirpstack.
My settings here for rak3172 end device
Komut,Değer
AT+DEBUG=1,
AT+CLASS=C,
AT+NWM=1,
AT+NJM=1,
AT+MASK=0002,
AT+BAND=5,
AT+ADR=1,
AT+CFM=0,
AT+CHE=1:2,
AT+DCS=0,
AT+RX2FQ=923300000,
AT+DEVEUI=5E9D1E0857CF25F7,
AT+APPEUI=5E9D1E0857CF25F7,
AT+APPKEY=F921D50CD7D02EE3C5E6142154F274B7,
AT+JOIN=1:0:10:8,
I was using same setting and it was connected and sended message rak2245 gateway.
Sorry for my english ![]()
OK
Received data:
+EVT:JOINED
Receiving MLME_JOIN
DevAddr:01b67791
AT+SEND=2:0A0B0C0D0E
QueryTxPossible: OK, UserDataSize 5 PossibleDataSize 11 AdditionalFOptsSize 0
Frequency:902300000
Rx1Frequency:923300000
RxCFrequency:923300000
ChannelsDatarate:0
ChannelsTxPower:0
FCntUp:1
OK
Received data:
+EVT:SEND_CONFIRMED_FAILED(4)
– Journal begins at Tue 2024-10-22 13:00:30 UTC. –
Jan 06 22:05:17 rak-gateway ttn-gateway[631]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Jan 06 22:05:17 rak-gateway ttn-gateway[631]: # RF packets sent to concentrator: 0 (0 bytes)
Jan 06 22:05:17 rak-gateway ttn-gateway[631]: # TX errors: 0
Jan 06 22:05:17 rak-gateway ttn-gateway[631]: ### SX1302 Status ###
Jan 06 22:05:17 rak-gateway ttn-gateway[631]: # SX1302 counter (INST): 120723797
Jan 06 22:05:17 rak-gateway ttn-gateway[631]: # SX1302 counter (PPS): 0
Jan 06 22:05:17 rak-gateway ttn-gateway[631]: # BEACON queued: 0
Jan 06 22:06:47 rak-gateway ttn-gateway[631]: # BEACON sent so far: 0
Jan 06 22:06:47 rak-gateway ttn-gateway[631]: # BEACON rejected: 0
Jan 06 22:06:47 rak-gateway ttn-gateway[631]: ### [JIT] ###
Jan 06 22:06:47 rak-gateway ttn-gateway[631]: src/jitqueue.c:440:jit_print_queue(): INFO: [jit] queue is empty
Jan 06 22:06:47 rak-gateway ttn-gateway[631]: #--------
Jan 06 22:06:47 rak-gateway ttn-gateway[631]: ### [GPS] ###
Jan 06 22:06:47 rak-gateway ttn-gateway[631]: # Invalid time reference (age: 1736201117 sec)
Jan 06 22:06:47 rak-gateway ttn-gateway[631]: # no valid GPS coordinates available yet
Jan 06 22:06:47 rak-gateway ttn-gateway[631]: ##### END #####
Jan 06 22:06:47 rak-gateway ttn-gateway[631]: JSON up: {“stat”:{“time”:“2025-01-06 22:05:17 GMT”,“rxnb”:0,“rxok”:0,“rxfw”:0,“ackr”:100.0,“dwnb”:0,“txnb”:0,“temp”:0.0}}
Jan 06 22:06:47 rak-gateway ttn-gateway[631]: INFO: [up] PUSH_ACK received in 1 ms
Jan 06 22:06:47 rak-gateway ttn-gateway[631]: INFO: [down] PULL_ACK received in 0 ms
Jan 06 22:06:47 rak-gateway ttn-gateway[631]: INFO: Received pkt from mote: 0000015D (fcnt=65280)
Jan 06 22:06:47 rak-gateway ttn-gateway[631]: JSON up: {“rxpk”:[{“jver”:1,“tmst”:132957052,“chan”:8,“rfch”:0,“freq”:904.600000,“mid”:16,“stat”:1,“modu”:“LORA”,“datr”:“SF8BW500”,“codr”:“4/5”,“rssis”:-56,“lsnr”:15.8,“foff”:638,“rssi”:-56,“size”:23,“data”:“AF0BAAAAAP9IXQEw/v9j5kjcgaQi+H0=”}]}
Jan 06 22:06:47 rak-gateway ttn-gateway[631]: INFO: [up] PUSH_ACK received in 2 ms
Jan 06 22:06:47 rak-gateway ttn-gateway[631]: ##### 2025-01-06 22:05:47 GMT #####
Jan 06 22:06:47 rak-gateway ttn-gateway[631]: ### [UPSTREAM] ###
Jan 06 22:06:47 rak-gateway ttn-gateway[631]: # RF packets received by concentrator: 1
Jan 06 22:06:47 rak-gateway ttn-gateway[631]: # CRC_OK: 100.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Jan 06 22:06:47 rak-gateway ttn-gateway[631]: # RF packets forwarded: 1 (23 bytes)
Jan 06 22:06:47 rak-gateway ttn-gateway[631]: # PUSH_DATA datagrams sent: 2 (371 bytes)
Jan 06 22:06:47 rak-gateway ttn-gateway[631]: # PUSH_DATA acknowledged: 100.00%
Jan 06 22:06:47 rak-gateway ttn-gateway[631]: ### [DOWNSTREAM] ###
Jan 06 22:06:47 rak-gateway ttn-gateway[631]: # PULL_DATA sent: 3 (100.00% acknowledged)
Jan 06 22:06:47 rak-gateway ttn-gateway[631]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Jan 06 22:06:47 rak-gateway ttn-gateway[631]: # RF packets sent to concentrator: 0 (0 bytes)
Jan 06 22:06:47 rak-gateway ttn-gateway[631]: # TX errors: 0
Jan 06 22:06:47 rak-gateway ttn-gateway[631]: ### SX1302 Status ###
Jan 06 22:06:47 rak-gateway ttn-gateway[631]: # SX1302 counter (INST): 150722976
Jan 06 22:06:47 rak-gateway ttn-gateway[631]: # SX1302 counter (PPS): 0
Jan 06 22:06:47 rak-gateway ttn-gateway[631]: # BEACON queued: 0
Jan 06 22:06:47 rak-gateway ttn-gateway[631]: # Invalid time reference (age: 1736201147 sec)
Jan 06 22:06:47 rak-gateway ttn-gateway[631]: JSON up: {“stat”:{“time”:“2025-01-06 22:05:47 GMT”,“rxnb”:1,“rxok”:1,“rxfw”:1,“ackr”:100.0,“dwnb”:0,“txnb”:0,“temp”:0.0}}
Jan 06 22:06:47 rak-gateway ttn-gateway[631]: INFO: [up] PUSH_ACK received in 0 ms
Jan 06 22:06:47 rak-gateway ttn-gateway[631]: ##### 2025-01-06 22:06:17 GMT #####
Jan 06 22:06:47 rak-gateway ttn-gateway[631]: # RF packets received by concentrator: 0
Jan 06 22:06:47 rak-gateway ttn-gateway[631]: # CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Jan 06 22:06:47 rak-gateway ttn-gateway[631]: # RF packets forwarded: 0 (0 bytes)
Jan 06 22:06:47 rak-gateway ttn-gateway[631]: # PUSH_DATA datagrams sent: 1 (124 bytes)
Jan 06 22:06:47 rak-gateway ttn-gateway[631]: # SX1302 counter (INST): 180722828
Jan 06 22:06:47 rak-gateway ttn-gateway[631]: # Invalid time reference (age: 1736201177 sec)
Jan 06 22:06:47 rak-gateway ttn-gateway[631]: JSON up: {“stat”:{“time”:“2025-01-06 22:06:17 GMT”,“rxnb”:0,“rxok”:0,“rxfw”:0,“ackr”:100.0,“dwnb”:0,“txnb”:0,“temp”:0.0}}
Jan 06 22:06:47 rak-gateway ttn-gateway[631]: INFO: Received pkt from mote: 57CF25F7 (fcnt=40222)
Jan 06 22:06:47 rak-gateway ttn-gateway[631]: JSON up: {“rxpk”:[{“jver”:1,“tmst”:194086873,“chan”:3,“rfch”:0,“freq”:904.500000,“mid”: 9,“stat”:1,“modu”:“LORA”,“datr”:“SF10BW125”,“codr”:“4/5”,“rssis”:-47,“lsnr”:12.8,“foff”:-4441,“rssi”:-46,“size”:23,“data”:“APclz1cIHp1e9yXPVwgenV6VA8CXaPE=”}]}
Jan 06 22:06:47 rak-gateway ttn-gateway[631]: INFO: [down] PULL_RESP received - token[107:41] ![]()
Jan 06 22:06:47 rak-gateway ttn-gateway[631]: JSON down: {“txpk”:{“imme”:false,“rfch”:0,“powe”:21,“ant”:0,“brd”:0,“tmst”:199086873,“freq”:925.1,“modu”:“LORA”,“datr”:“SF10BW500”,“codr”:“4/5”,“ipol”:true,“size”:33,“data”:“INC6vOx6Te09mBv6+SwCkrpTFclNnO4WplLNPIX9AFNT”}}
Jan 06 22:06:47 rak-gateway ttn-gateway[631]: ##### 2025-01-06 22:06:47 GMT #####
Jan 06 22:06:47 rak-gateway ttn-gateway[631]: # PUSH_DATA datagrams sent: 2 (374 bytes)
Jan 06 22:08:17 rak-gateway ttn-gateway[631]: # PULL_DATA sent: 3 (100.00% acknowledged)
Jan 06 22:08:17 rak-gateway ttn-gateway[631]: # PULL_RESP(onse) datagrams received: 1 (214 bytes)
Jan 06 22:08:17 rak-gateway ttn-gateway[631]: # RF packets sent to concentrator: 1 (33 bytes)
Jan 06 22:08:17 rak-gateway ttn-gateway[631]: # TX errors: 0
Jan 06 22:08:17 rak-gateway ttn-gateway[631]: # TX rejected (collision packet): 0.00% (req:1, rej:0)
Jan 06 22:08:17 rak-gateway ttn-gateway[631]: # TX rejected (collision beacon): 0.00% (req:1, rej:0)
Jan 06 22:08:17 rak-gateway ttn-gateway[631]: # TX rejected (too late): 0.00% (req:1, rej:0)
Jan 06 22:08:17 rak-gateway ttn-gateway[631]: # TX rejected (too early): 0.00% (req:1, rej:0)
Jan 06 22:08:17 rak-gateway ttn-gateway[631]: ### SX1302 Status ###
Jan 06 22:08:17 rak-gateway ttn-gateway[631]: # SX1302 counter (INST): 210722771
Jan 06 22:08:17 rak-gateway ttn-gateway[631]: # SX1302 counter (PPS): 0
Jan 06 22:08:17 rak-gateway ttn-gateway[631]: # BEACON queued: 0
Jan 06 22:08:17 rak-gateway ttn-gateway[631]: # BEACON sent so far: 0
Jan 06 22:08:17 rak-gateway ttn-gateway[631]: # BEACON rejected: 0
Jan 06 22:08:17 rak-gateway ttn-gateway[631]: ### [JIT] ###
Jan 06 22:08:17 rak-gateway ttn-gateway[631]: src/jitqueue.c:440:jit_print_queue(): INFO: [jit] queue is empty
Jan 06 22:08:17 rak-gateway ttn-gateway[631]: #--------
Jan 06 22:08:17 rak-gateway ttn-gateway[631]: ### [GPS] ###
Jan 06 22:08:17 rak-gateway ttn-gateway[631]: # Invalid time reference (age: 1736201207 sec)
Jan 06 22:08:17 rak-gateway ttn-gateway[631]: # no valid GPS coordinates available yet
Jan 06 22:08:17 rak-gateway ttn-gateway[631]: ##### END #####
Jan 06 22:08:17 rak-gateway ttn-gateway[631]: JSON up: {“stat”:{“time”:“2025-01-06 22:06:47 GMT”,“rxnb”:1,“rxok”:1,“rxfw”:1,“ackr”:100.0,“dwnb”:1,“txnb”:1,“temp”:0.0}}
Jan 06 22:08:17 rak-gateway ttn-gateway[631]: INFO: [up] PUSH_ACK received in 0 ms
Jan 06 22:08:17 rak-gateway ttn-gateway[631]: INFO: [down] PULL_ACK received in 0 ms
Jan 06 22:08:17 rak-gateway ttn-gateway[631]: ##### 2025-01-06 22:07:17 GMT #####
Jan 06 22:08:17 rak-gateway ttn-gateway[631]: ### [UPSTREAM] ###
Jan 06 22:08:17 rak-gateway ttn-gateway[631]: # RF packets received by concentrator: 0
Jan 06 22:08:17 rak-gateway ttn-gateway[631]: # CRC_OK: 0.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
Jan 06 22:08:17 rak-gateway ttn-gateway[631]: # RF packets forwarded: 0 (0 bytes)
Jan 06 22:08:17 rak-gateway ttn-gateway[631]: # PUSH_DATA datagrams sent: 1 (124 bytes)
Jan 06 22:08:17 rak-gateway ttn-gateway[631]: # PUSH_DATA acknowledged: 100.00%
Jan 06 22:08:17 rak-gateway ttn-gateway[631]: ### [DOWNSTREAM] ###
Jan 06 22:08:17 rak-gateway ttn-gateway[631]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Jan 06 22:08:17 rak-gateway ttn-gateway[631]: # RF packets sent to concentrator: 0 (0 bytes)
Jan 06 22:08:17 rak-gateway ttn-gateway[631]: # SX1302 counter (INST): 240722549
Jan 06 22:08:17 rak-gateway ttn-gateway[631]: # Invalid time reference (age: 1736201237 sec)
Jan 06 22:08:17 rak-gateway ttn-gateway[631]: JSON up: {“stat”:{“time”:“2025-01-06 22:07:17 GMT”,“rxnb”:0,“rxok”:0,“rxfw”:0,“ackr”:100.0,“dwnb”:0,“txnb”:0,“temp”:0.0}}
Jan 06 22:08:17 rak-gateway ttn-gateway[631]: ##### 2025-01-06 22:07:47 GMT #####
Jan 06 22:08:17 rak-gateway ttn-gateway[631]: # SX1302 counter (INST): 270722454
Jan 06 22:08:17 rak-gateway ttn-gateway[631]: # Invalid time reference (age: 1736201267 sec)
Jan 06 22:08:17 rak-gateway ttn-gateway[631]: JSON up: {“stat”:{“time”:“2025-01-06 22:07:47 GMT”,“rxnb”:0,“rxok”:0,“rxfw”:0,“ackr”:100.0,“dwnb”:0,“txnb”:0,“temp”:0.0}}
Jan 06 22:08:17 rak-gateway ttn-gateway[631]: INFO: [up] PUSH_ACK received in 1 ms
Jan 06 22:08:17 rak-gateway ttn-gateway[631]: ##### 2025-01-06 22:08:17 GMT #####
