922.1 MHz
922.3 MHz
922.5 MHz
Please let me know if there is any way to remove the above frequency from the gateway or set it to chirpstack to set the above frequency value to DR 0
If your goal is to change the DR of the end device’s uplink messages, then you need to change configurations on your end-device, i.e. turn off adaptive data rate (ADR) and specify a fixed data rate setting. Note also that the LoRaWAN regional parameters specify fixed data rates for the Join Procedure.
