I have encountered an issue with my RAK7289CV2 gateway where the downlink data rate (RX2 DR) does not update as expected when changed from the default setting. This issue persists across different operational configurations and results in downlink messages being transmitted at the incorrect data rate.
Environment:
Model: RAK7289CV2 (WisGate Edge Pro, 16-Channel)
WisGateOS:
v2.2.1(WisGateOS_2.2.1_RAK) -
Region: EU868
Frequency Plan: see screenshot
default_frequency_plan_EU868.png -
Device Class: Class C (continuous listening)
Intended Downlink DR: DR5 (attempted to set via the WisGate OS web interface), see screenshot:
DR5_test_parameters.png -
Actual Downlink DR: DR0 (despite settings indicating otherwise), see screenshot from Gateway Packet Capture
Configuration and Tests Performed:
- Frequency: Tested DR5 setting with different frequencies, e.g., 868.3 and 869.525.
- ADR: Tested with both enabled and disabled states.
- Message Types: Tested with both Confirmed and Unconfirmed messages.
- Downlink Message Initiation: Tested sending downlink messages via both MQTT and the WisGate OS web-interface’s downlink page.
- LoRaWAN Version: Teste different protocol versions including 1.0.2 Rev A, 1.0.2 Rev B, 1.0.3
- Frame-counter Validation: Tested with both enabled/disabled.
Observed Behavior:
- When the RX2 data rate is set to DR5 via the WisGate OS interface, the downlink messages continue to be sent at DR0. This has been confirmed by observing the gateway’s packet capture logs.
- see screenshot from Gateway Packet Capture
- The issue arises when changing the RX2 data rate from the default setting (DR0) to any other data rate (e.g., DR5). The gateway seems to ignore the updated setting and sends downlink messages at DR0 instead.
- see
- see
- Apart from the fact that the message was sent with DR0 (instead of the intended DR5), the end device does not receive the message in this scenario.
Troubleshooting Steps Already Taken:
- Verified that changes to RX2 DR are saved correctly in the WisGate OS interface.
- Rebooted the gateway after applying changes to ensure they are in effect.
Potential Impact:
- This issue hinders the correct operation of Class C devices in the network, as they are unable to receive downlinks at the intended data rate, potentially impacting critical device functions.
I verified that my end-device in Class C configuration receives downlink messages normally when the “default settings” are used with “intended DR0”, see screenshots:
I believe this might be a bug within the WisGate OS or the packet forwarder for the RAK7289CV2 gateway. I am reaching out to seek assistance in resolving this issue or to identify if a firmware update is required to address this anomaly.
Please find attached screenshots of the WisGate OS interface showing the RX2 data rate settings, along with packet capture logs demonstrating the downlink messages being sent at DR0 instead of the configured DR5.
I appreciate any guidance or insights on this issue.
DR5_test_parameters:
test_with_default_DR0:
default_frequency_plan_EU868:
DR0_but_should_be_DR5:
DR0_settings:
