FraCaPr
(Franco)
January 30, 2020, 6:00pm
1
Hi, im using the read_partition/wirte_partition Functions to save 1 counter inside the structure of g_lora_config. The code was modified to understand my problem:
if (read_partition(PARTITION_0, (char *)&g_lora_config, sizeof(g_lora_config)) < 0) {
e_printf(RAK_RD_CFG_ERR); }
g_lora_config.Cont= 0;
write_partition(PARTITION_0, (char *)&g_lora_config, sizeof(g_lora_config));
e_printf("OK\r\n");
while(1) {
g_lora_config.Cont= g_lora_config.Cont +1;
HAL_Delay(1000);
e_printf("OK\r\n");
If i see the Serial :
Welcome to RAK811.
Selected LoraWAN 1.0.2 Region: US915
The Hard Fault exception occurs,Reset!
Welcome to RAK811.
FraCaPr
(Franco)
January 31, 2020, 4:30pm
2
I also can get this :
Return of Read USR Config: -1
Table crc error! base_addr:0x801ea00 , crc:0x913f
This is the Function:
int read_partition(partition_index partition, char *out, uint16_t out_len)
uint16_t crc;
table_header_t table;
uint32_t base_addr;
base_addr = get_active_partition(partition);
read_data(base_addr, &table, sizeof(table_header_t));
p_log("R- base_addr:0x%x ,crc:0x%x\r\n", base_addr, table.crc);
if (table.magic != PARTITION_MAGIC_WORD) {
p_log("Table magic error! base_addr:0x%x\r\n", base_addr);
e_printf("Table magic error! base_addr:0x%x\r\n", base_addr);
return -1;
if (table.length != out_len) {
p_log("Table length error! base_addr:0x%x\r\n", base_addr);
e_printf("Table length error! base_addr:0x%x\r\n", base_addr);
return -1;
read_data(base_addr + sizeof(table_header_t), out, table.length);
crc = crc_calc(0, out, out + table.length);
if (crc != table.crc) {
p_log("Table crc error! base_addr:0x%x , crc:0x%x\r\n", base_addr, crc);
e_printf("Table crc error! base_addr:0x%x , crc:0x%x\r\n", base_addr, crc);
return -1;
return 0;
So, the base_addr was change after the Sleeping, i dont know why
base_addr:0x801e200 , crc:0x56c
Sending Data…
at+recv=1,0,0
TX_CONFIRMED ok!
JOIN COUNTER 0
Sleeping
Welcome to RAK811.
base_addr:0x801ea00 , crc:0x56c
Table crc error! base_addr:0x801ea00 , crc:0xfc07
Return Read USR CFG: -1
Using default settings
leopold
(wang)
February 1, 2020, 4:42pm
3
Hi,@FraCaPr
Which project’s firmware are you using?
FraCaPr
(Franco)
February 3, 2020, 3:48pm
4
hi, i’m using the last version :
RAKwireless,RAK811,Lora Module,WisNode_LoRa,SDK,AT Command - RAKWireless/RAK811
but i “solved” using this function:
write_data(addres,buffer,sizeof(buffer)) ;
read_data(addres,buffer,sizeof(buffer)) ;
leopold
(wang)
February 4, 2020, 4:37am
5
Hi @FraCaPr
This exception is caused by stack space overflow possibly. Finding this problem is complicated.So you need check your app logic.
FraCaPr:
base_addr: 0x801ea00 , crc:0x56c
base_addr: 0x801e200 , crc:0x56c
You’d better execute twice in a row “write_partition(PARTITION_0, (char *)&g_lora_config, sizeof(g_lora_config));”
in fuction “int write_partition(partition_index partition, char *out, uint16_t out_len)”. It is possible that flash is not fully unlocked, so do once write to unlock it first,then write flash normally .
This open source code is very old and will not be updated.So you could try our RUI:https://forum.rakwireless.com/t/rak-online-compiler-for-you-to-compile-your-customized-firmware-based-on-rui/662
