Dear All,
i’m Gianmario from Italy and i’m prototiping a WisBlock based on RAK 5005, with RAK4631 and GPS, temp and humidity, accelerometer 3 axis . I wrote an arduino program starting from the examples and i had add the code for the sensors and on serial all look like going good as u can see on the bottom of this post , but on The Things network i seen only the OTAA connection . So i integrated MyDevice as experiment because i doesn’t seen any data , and from MyDevices i receive only the Timestamp
I have a gateway 2 channels of Heltec , model HT-M00
i attach the code :**
@file LoRaWAN_OTAA_ABP.ino
@author rakwireless.com
@brief LoRaWan node example with OTAA/ABP registration
@version 0.1
@date 2020-08-21
@copyright Copyright (c) 2020
@note RAK4631 GPIO mapping to nRF52840 GPIO ports
RAK4631 <-> nRF52840
WB_IO1 <-> P0.17 (GPIO 17)
WB_IO2 <-> P1.02 (GPIO 34)
WB_IO3 <-> P0.21 (GPIO 21)
WB_IO4 <-> P0.04 (GPIO 4)
WB_IO5 <-> P0.09 (GPIO 9)
WB_IO6 <-> P0.10 (GPIO 10)
WB_SW1 <-> P0.01 (GPIO 1)
WB_A0 <-> P0.04/AIN2 (AnalogIn A2)
WB_A1 <-> P0.31/AIN7 (AnalogIn A7)
#include <Arduino.h>
#include <SPI.h>
#include "SparkFun_SHTC3.h" //Click here to get the library: http://librarymanager/All#SparkFun_SHTC3
SHTC3 g_shtc3; // Declare an instance of the SHTC3 class
// RAK4630 supply two LED
#ifndef LED_BUILTIN
#define LED_BUILTIN 35
#endif
#ifndef LED_BUILTIN2
#define LED_BUILTIN2 36
#endif
#define LORAWAN_DATERATE DR_0 /*LoRaMac datarates definition, from DR_0 to DR_5*/
#define LORAWAN_TX_POWER TX_POWER_5 /*LoRaMac tx power definition, from TX_POWER_0 to TX_POWER_15*/
DeviceClass_t g_CurrentClass = CLASS_A; /* class definition*/
LoRaMacRegion_t g_CurrentRegion = LORAMAC_REGION_EU868; /* Region:EU868*/
lmh_confirm g_CurrentConfirm = LMH_CONFIRMED_MSG; /* confirm/unconfirm packet definition*/
static lmh_param_t g_lora_param_init = {LORAWAN_ADR_ON, LORAWAN_DATERATE, LORAWAN_PUBLIC_NETWORK, JOINREQ_NBTRIALS, LORAWAN_TX_POWER, LORAWAN_DUTYCYCLE_OFF};
// Foward declaration
static lmh_callback_t g_lora_callbacks = {BoardGetBatteryLevel, BoardGetUniqueId, BoardGetRandomSeed,
lorawan_rx_handler, lorawan_has_joined_handler, lorawan_confirm_class_handler, lorawan_join_failed_handler
//OTAA keys !!!! KEYS ARE MSB !!!!001D49E711CECDAB
uint8_t nodeDeviceEUI[8] = { 0x00, 0x1D, 0x49, 0xE7, 0x11, 0xCE, 0xCD, 0xAB };
uint8_t nodeAppEUI[8] = { 0x70, 0xB3, 0xD5, 0x7E, 0xD0, 0x04, 0x14, 0x80 };
uint8_t nodeAppKey[16] = { 0x78, 0xDE, 0x42, 0x3A, 0xDD, 0xF4, 0xB6, 0x38, 0x6A, 0xDF, 0x0F, 0xA7, 0x7E, 0xEE, 0xA5, 0x3C };
// ABP keys
uint32_t nodeDevAddr = 0x260116F8;
uint8_t nodeNwsKey[16] = {0x7E, 0xAC, 0xE2, 0x55, 0xB8, 0xA5, 0xE2, 0x69, 0x91, 0x51, 0x96, 0x06, 0x47, 0x56, 0x9D, 0x23};
uint8_t nodeAppsKey[16] = {0xFB, 0xAC, 0xB6, 0x47, 0xF3, 0x58, 0x45, 0xC7, 0x50, 0x7D, 0xBF, 0x16, 0x8B, 0xA8, 0xC1, 0x7C};
// Private defination
#define LORAWAN_APP_INTERVAL 20000 /**< Defines for user timer, the application data transmission interval. 20s, value in [ms]. */
TimerEvent_t appTimer;
static uint32_t count = 0;
// sensore BM
void errorDecoder(SHTC3_Status_TypeDef message) // The errorDecoder function prints "SHTC3_Status_TypeDef" resultsin a human-friendly way
switch (message)
case SHTC3_Status_Nominal:
Serial.print("Nominal");
break;
case SHTC3_Status_Error:
Serial.print("Error");
break;
case SHTC3_Status_CRC_Fail:
Serial.print("CRC Fail");
break;
default:
Serial.print("Unknown return code");
break;
void shtc3_read_data(void)
float Temperature = 0;
float Humidity = 0;
g_shtc3.update();
if (g_shtc3.lastStatus == SHTC3_Status_Nominal) // You can also assess the status of the last command by checking the ".lastStatus" member of the object
Temperature = g_shtc3.toDegC(); // Packing LoRa data
Humidity = g_shtc3.toPercent();
Serial.print("RH = ");
Serial.print(g_shtc3.toPercent()); // "toPercent" returns the percent humidity as a floating point number
Serial.print("% (checksum: ");
if (g_shtc3.passRHcrc) // Like "passIDcrc" this is true when the RH value is valid from the sensor (but not necessarily up-to-date in terms of time)
Serial.print("pass");
else
Serial.print("fail");
Serial.print("), T = ");
Serial.print(g_shtc3.toDegC()); // "toDegF" and "toDegC" return the temperature as a flaoting point number in deg F and deg C respectively
Serial.print(" deg C (checksum: ");
if (g_shtc3.passTcrc) // Like "passIDcrc" this is true when the T value is valid from the sensor (but not necessarily up-to-date in terms of time)
else
Serial.println(")");
else
Serial.print("Update failed, error: ");
errorDecoder(g_shtc3.lastStatus);
Serial.println();
void setup()
pinMode(LED_BUILTIN, OUTPUT);
// Initialize LoRa chip.
lora_rak4630_init();
time_t timeout = millis();
while (!Serial)
delay(100);
else
break;
if (doOTAA)
Serial.println("Type: OTAA");
else
Serial.println("Type: ABP");
switch (g_CurrentRegion)
case LORAMAC_REGION_AS923:
break;
case LORAMAC_REGION_AU915:
break;
case LORAMAC_REGION_CN470:
break;
case LORAMAC_REGION_EU433:
break;
case LORAMAC_REGION_IN865:
break;
case LORAMAC_REGION_EU868:
break;
case LORAMAC_REGION_KR920:
break;
case LORAMAC_REGION_US915:
break;
while (!Serial)
delay(100);
else
break;
Wire.begin();
Serial.println("shtc3 init");
Serial.print("Beginning sensor. Result = "); // Most SHTC3 functions return a variable of the type "SHTC3_Status_TypeDef" to indicate the status of their execution
errorDecoder(g_shtc3.begin()); // To start the sensor you must call "begin()", the default settings use Wire (default Arduino I2C port)
Wire.setClock(400000); // The sensor is listed to work up to 1 MHz I2C speed, but the I2C clock speed is global for all sensors on that bus so using 400kHz or 100kHz is recommended
Serial.println();
if (g_shtc3.passIDcrc) // Whenever data is received the associated checksum is calculated and verified so you can be sure the data is true
{ // The checksum pass indicators are: passIDcrc, passRHcrc, and passTcrc for the ID, RH, and T readings respectively
Serial.print("ID Passed Checksum. ");
Serial.print("Device ID: 0b");
Serial.println(g_shtc3.ID, BIN); // The 16-bit device ID can be accessed as a member variable of the object
else
Serial.println("ID Checksum Failed. ");
// fine sensore BM
uint32_t err_code;
err_code = timers_init();
if (err_code != 0)
return;
// Setup the EUIs and Keys
if (doOTAA)
lmh_setDevEui(nodeDeviceEUI);
lmh_setAppEui(nodeAppEUI);
lmh_setAppKey(nodeAppKey);
else
lmh_setNwkSKey(nodeNwsKey);
lmh_setAppSKey(nodeAppsKey);
lmh_setDevAddr(nodeDevAddr);
// Initialize LoRaWan
err_code = lmh_init(&g_lora_callbacks, g_lora_param_init, doOTAA, g_CurrentClass, g_CurrentRegion);
if (err_code != 0)
return;
// Start Join procedure
lmh_join();
void loop()
// Put your application tasks here, like reading of sensors,
// Controlling actuators and/or other functions.
shtc3_read_data();
delay(1000);
send_lora_frame();
/**@brief LoRa function for handling HasJoined event.
if (ret == LMH_SUCCESS)
delay(1000);
TimerStart(&appTimer);
@param[in] app_data Pointer to rx data
m_lora_app_data.buffsize = 0;
lmh_send(&m_lora_app_data, g_CurrentConfirm);
//Not joined, try again later
return;
uint32_t i = 0;
m_lora_app_data.buffer[i++] = 'H';
m_lora_app_data.buffer[i++] = 'e';
m_lora_app_data.buffer[i++] = 'l';
m_lora_app_data.buffer[i++] = 'o';
m_lora_app_data.buffer[i++] = '!';
m_lora_app_data.buffsize = i;
if (error == LMH_SUCCESS)
count++;
else
count_fail++;
/**@brief Function for handling user timerout event.
shtc3_read_data();
send_lora_frame();
@details Initializes the timer module. This creates and starts application timers.
return 0;
THE OUTPUT :
13:50:46.443 -> =====================================
13:50:46.443 -> Welcome to RAK4630 LoRaWan!!!
13:50:46.443 -> Type: OTAA
13:50:46.443 -> Region: EU868
13:50:46.443 -> shtc3 init
13:50:46.443 -> Beginning sensor. Result = Nominal
13:50:46.443 -> ID Passed Checksum. Device ID: 0b100001000111
13:50:46.443 -> <LMH> OTAA
13:50:46.443 -> DevEui=00-1D-49-E7-11-CE-CD-AB
13:50:46.443 -> DevAdd=00000000
13:50:46.443 -> AppEui=70-B3-D5-7E-D0-04-14-80
13:50:46.443 -> AppKey=78-DE-42-3A-DD-F4-B6-38-6A-DF-0F-A7-7E-EE-A5-3C
13:50:46.508 -> <LMH> Selected subband 1
13:50:46.541 ->
13:50:46.541 -> BSP Library : 0.21.20
13:50:46.541 -> Bootloader : s140 6.1.1
13:50:46.541 -> Serial No : B778DD5D8C63174C
13:50:46.541 ->
13:50:46.541 -> RH = 30.97% (checksum: pass), T = 26.58 deg C (checksum: pass)
13:50:46.608 -> <LM> OnRadioTxDone
13:50:47.572 -> <LM> OnRadioTxDone => RX Windows #1 4989 #2 5995
13:50:47.572 -> <LM> OnRadioTxDone => TX was Join Request
13:50:47.572 -> RH = 30.96% (checksum: pass), T = 26.60 deg C (checksum: pass)
13:50:48.568 -> RH = 30.97% (checksum: pass), T = 26.58 deg C (checksum: pass)
13:50:49.601 -> RH = 30.98% (checksum: pass), T = 26.59 deg C (checksum: pass)
13:50:50.600 -> RH = 30.98% (checksum: pass), T = 26.60 deg C (checksum: pass)
13:50:51.600 -> RH = 30.99% (checksum: pass), T = 26.61 deg C (checksum: pass)
13:50:51.667 -> <LM> OnRadioRxDone
13:50:51.667 -> <LM> OnRadioRxDone => FRAME_TYPE_JOIN_ACCEPT
13:50:51.667 -> OTAA Mode, Network Joined!
13:50:52.631 -> lmh_send ok count 1
13:50:52.631 -> RH = 30.98% (checksum: pass), T = 26.59 deg C (checksum: pass)
13:50:53.629 -> <LM> LoRaMacMcpsRequest LORAMAC_STATUS_BUSY
13:50:53.629 -> <LMH> lmh_send -> LoRaMacMcpsRequest failed
13:50:53.629 -> lmh_send fail count 1
13:50:53.662 -> RH = 31.00% (checksum: pass), T = 26.60 deg C (checksum: pass)
13:50:53.962 -> <LM> OnRadioTxDone
13:50:54.657 -> <LM> OnRadioTxDone => RX Windows #1 1030 #2 1995
13:50:54.657 -> <LM> LoRaMacMcpsRequest LORAMAC_STATUS_BUSY
13:50:54.657 -> <LMH> lmh_send -> LoRaMacMcpsRequest failed
13:50:54.657 -> lmh_send fail count 2
13:50:54.657 -> RH = 30.98% (checksum: pass), T = 26.61 deg C (checksum: pass)
13:50:55.653 -> <LM> LoRaMacMcpsRequest LORAMAC_STATUS_BUSY
13:50:55.653 -> <LMH> lmh_send -> LoRaMacMcpsRequest failed
13:50:55.653 -> lmh_send fail count 3
13:50:55.702 -> RH = 30.98% (checksum: pass), T = 26.58 deg C (checksum: pass)
13:50:56.669 -> <LM> LoRaMacMcpsRequest LORAMAC_STATUS_BUSY
13:50:56.669 -> <LMH> lmh_send -> LoRaMacMcpsRequest failed
13:50:56.669 -> lmh_send fail count 4
13:50:56.702 -> RH = 30.99% (checksum: pass), T = 26.59 deg C (checksum: pass)
13:50:57.702 -> <LM> LoRaMacMcpsRequest LORAMAC_STATUS_BUSY
13:50:57.702 -> <LMH> lmh_send -> LoRaMacMcpsRequest failed
13:50:57.702 -> lmh_send fail count 5
13:50:57.702 -> RH = 30.97% (checksum: pass), T = 26.62 deg C (checksum: pass)
13:50:58.701 -> <LM> LoRaMacMcpsRequest LORAMAC_STATUS_BUSY
13:50:58.701 -> <LMH> lmh_send -> LoRaMacMcpsRequest failed
13:50:58.701 -> lmh_send fail count 6
13:50:58.701 -> RH = 31.01% (checksum: pass), T = 26.61 deg C (checksum: pass)
13:50:58.999 -> <RADIO> RadioIrqProcess => IRQ_RX_TX_TIMEOUT
13:50:58.999 -> <LM> OnRadioRxTimeout
13:50:59.694 -> <LM> LoRaMacMcpsRequest LORAMAC_STATUS_BUSY
13:50:59.694 -> <LMH> lmh_send -> LoRaMacMcpsRequest failed
13:50:59.694 -> lmh_send fail count 7
13:50:59.728 -> RH = 31.00% (checksum: pass), T = 26.63 deg C (checksum: pass)
13:51:00.458 -> <LM> OnRadioTxDone
13:51:00.724 -> <LM> OnRadioTxDone => RX Windows #1 1030 #2 1995
13:51:00.724 -> <LM> LoRaMacMcpsRequest LORAMAC_STATUS_BUSY
13:51:00.724 -> <LMH> lmh_send -> LoRaMacMcpsRequest failed
13:51:00.724 -> lmh_send fail count 8
13:51:00.724 -> RH = 30.98% (checksum: pass), T = 26.63 deg C (checksum: pass)
13:51:01.722 -> <LM> LoRaMacMcpsRequest LORAMAC_STATUS_BUSY
13:51:01.722 -> <LMH> lmh_send -> LoRaMacMcpsRequest failed
13:51:01.722 -> lmh_send fail count 9
13:51:01.755 -> RH = 30.98% (checksum: pass), T = 26.61 deg C (checksum: pass)
13:51:02.752 -> <LM> LoRaMacMcpsRequest LORAMAC_STATUS_BUSY
13:51:02.752 -> <LMH> lmh_send -> LoRaMacMcpsRequest failed
13:51:02.752 -> lmh_send fail count 10
13:51:02.752 -> RH = 31.00% (checksum: pass), T = 26.66 deg C (checksum: pass)
13:51:03.750 -> <LM> LoRaMacMcpsRequest LORAMAC_STATUS_BUSY
13:51:03.750 -> <LMH> lmh_send -> LoRaMacMcpsRequest failed
13:51:03.750 -> lmh_send fail count 11
13:51:03.783 -> RH = 30.96% (checksum: pass), T = 26.62 deg C (checksum: pass)
13:51:04.782 -> <LM> LoRaMacMcpsRequest LORAMAC_STATUS_BUSY
13:51:04.782 -> <LMH> lmh_send -> LoRaMacMcpsRequest failed
13:51:04.782 -> lmh_send fail count 12
13:51:04.782 -> RH = 31.00% (checksum: pass), T = 26.65 deg C (checksum: pass)
13:51:05.512 -> <RADIO> RadioIrqProcess => IRQ_RX_TX_TIMEOUT
13:51:05.512 -> <LM> OnRadioRxTimeout
13:51:05.778 -> <LM> LoRaMacMcpsRequest LORAMAC_STATUS_BUSY
13:51:05.778 -> <LMH> lmh_send -> LoRaMacMcpsRequest failed
13:51:05.778 -> lmh_send fail count 13
13:51:05.778 -> RH = 31.00% (checksum: pass), T = 26.64 deg C (checksum: pass)
13:51:06.807 -> <LM> LoRaMacMcpsRequest LORAMAC_STATUS_BUSY
13:51:06.807 -> <LMH> lmh_send -> LoRaMacMcpsRequest failed
13:51:06.807 -> lmh_send fail count 14
And in the TTN i see only one row on my application’s console under the data panel " ACTIVATION " but any of other datas .
Please help me …
