RAK5860
How do I power it down and up?
#include "lora.h"
#include "cellular.h"
#define BG77_POWER_KEY WB_IO1
// Read the return value of BG77.
void BG77_read(time_t timeout)
time_t timeStamp = millis();
while ((millis() - timeStamp) < timeout)
if (Serial1.available() > 0)
Serial.print((char)Serial1.read());
delay(1);
GPSData BG77_read_gps(time_t timeout)
String gpsData = "";
gpsData += (char)Serial1.read();
delay(1);
gpsData.trim();
log("GPS", gpsData.c_str());
if (gpsData.indexOf("CME ERROR") != -1)
return {.success = false};
return {.success = true};
// Write commands to BG77.
void BG77_write(const char *command)
while (*command)
Serial1.write(*command);
command++;
Serial1.println();
bool setup_cellular(void)
log("BG77", "Setting up");
// Check if the modem is already awake
Serial1.begin(115200);
pinMode(BG77_POWER_KEY, OUTPUT);
delay(1000);
bool available = false;
time_t timeout = millis();
Serial1.println("ATI");
// BG77 init
while ((millis() - timeout) < 4000)
if (Serial1.available())
String result = Serial1.readString();
log("BG77", "Response after start");
Serial.println(result);
available = true;
if (!available) {
wakeup_cellular();
// Set UE Functionality to Full
BG77_write("AT+CFUN=1,0\r");
BG77_read(15000);
// Attach to PS
BG77_write("AT+CGATT=1\r");
BG77_read(2000);
// Query EPS Network Registration Status
BG77_write("AT+CEREG?\r");
BG77_read(2000);
// Query Network Information
BG77_write("AT+QNWINFO\r");
BG77_read(2000);
// Query and Report Signal Strength
BG77_write("AT+QCSQ\r");
BG77_read(2000);
// Set Supported GNSS Constellations to Auto
BG77_write("AT+QGPSCFG=\"gnssconfig\",5\r");
BG77_read(2000);
// Enable XTRA Function
BG77_write("AT+QGPSXTRA=1\r");
BG77_read(2000);
// Enable Automatic Downloading of XTRA
BG77_write("AT+QGPSCFG=\"xtra_autodownload\"\r");
BG77_read(2000);
// Query the Existing XTRA File Information
BG77_write("AT+QGPSCFG=\"xtra_info\"\r");
BG77_read(2000);
BG77_write("AT+CMGF=1\r");
BG77_read(2000);
// not working?
Serial1.println("AT+CMGS=\"+49x\"\r");
delay(1000);
Serial1.print("Test\r");
delay(100);
Serial1.write(26);
delay(5000);
BG77_read(5000);
delay(1000);
powerdown_cellular();
return true;
void wakeup_cellular(void) {
if (Serial1.available()) {
available = true;
if (available) {
return;
log("BG77", "Slept, waking up");
digitalWrite(BG77_POWER_KEY, LOW);
delay(1000);
digitalWrite(BG77_POWER_KEY, HIGH);
delay(2000);
delay(1000);
log("BG77", "Successfully powered up");
delay(1000);
void powerdown_cellular(void) {
log("BG77", "Powering down");
delay(1000);
delay(2000);
delay(1000);
log("BG77", "Successfully powered down");
GPSData get_gps(void)
// Turn on GNSS
BG77_write("AT+QGPS=1\r");
BG77_read(2000);
delay(20000);
// Acquire Positioning Information
// wont get fix
BG77_write("AT+QGPSLOC=2\r");
GPSData val = BG77_read_gps(2000);
// Turn off GNSS
BG77_write("AT+QGPSEND\r");
BG77_read(2000);
return val;
