I Don see Rak10701 Display Issues
I followed the instructions and am having trouble with the LoRaWAN Payload Decoder
@anh.nguyen , please try to use the decoder for Chirpstack V4 that I sent you via email/zendesk support and update us if that fixed the decoding problem.
I changed the code and waited for 8 hours. still no result
Rak10701 - Google Tài liệu
I have summarized the process and code file. Please double check . Thank you
The payload coming from Chirpstack makes no sense.
In you screenshot it says payload is AAAAAAAAAAAAAA== (Base 64) which translates to 00 00 00 00 00 00 00 00 00 00
But that is not a valid payload from the RAK10701.
Can you get the payload shown in Chirpstack?
Last payloads look okay.
Does decoder work now?
What did you change?
-I have reconnected, redo from step 1.
Data correct results
-decoder not working
That is strange, if I put your payload into the decoder I am running on Datacake, it works.
Can you share the complete content of the webhook data you received:
In the network server settings in Datacake, did you select the correct Chirpstack version?
I chose the correct version
webhook data
Is the attached decoder the same you are using right now?
decoder.zip (1.8 KB)
The encoder is working
sorry.
Decoder still doesn’t work
I don’t know why, but your payload is wrong again.
This is not a problem with the Datacake decoder. Your RAK10701 sends a wrong payload.
The payload TFYuJA== ==> 4c 56 2e 24 is too short. It should be 10 bytes long.
I don’t know why it would do this.
Is this Dev EUI from rak10701 ?
And what should i check from rak10701
You need to check in your RAK10701. I cannot (and should not) know the DevEUI
I checked devEUI , AppEUI,AppKey .it’s correct .can u utraview check wixtool box ?
and what is next step ?
Can you check the firmware version on your RAK10701?
I am using V1.1.2, which is the latest (I think).
Send through the WisToolBox console
ATC+VERSION=?
It should return something like
Field TesterVersion: v1.1.2
Build Time  Feb 28 2024  19:54:29
I will try the actility platform. Do you have a guide on actitily ?
