I will try the actility platform. Do you have a guide on actitily ?
No we do not have a guide for Actility. Only TTN, Chirpstack and Loriot.
I see error running payload decoer
Do you have another payload decoder ?
If rak10701 sends back 8 bit data.
Is it the manufacturer’s fault?
Can I change to another device?
I never saw that my device would send wrong payloads.
I think something else is wrong with your setup, but I can’t say what.
I run a two hours test this morning with the same firmware version, Chirpstack and Datacake and have no errors.
Here is an alternative way to create a backend server for the RAK10701 Field Tester.
it worked. but the distance is wrong
@anh.nguyen
Can you check the version of the field-tester-server you installed?
It is working for me.
(Same code, just different display and device)
