Issue :- Skipping of uplinks from the node to gateway.
Setup :-
Node : RAK3172 module
Gateway : Dragino LPS8N
Region : IN865
Antenna Gain :- 5dBi
Details :-
I have node and gateway setup with Lorawan Version 1.0.4 and Regional Parameters Version RP002-1.0.1. The node is sending uplinks at a frequency of 15 seconds (testing condition) to the gateway. But every now and then few uplinks get skipped. The node and the gateway both are set to IN865 region. Both the node and gateway are placed near each other. I have attached the serial debug logs (left) and the chirpstack data (right) below.
Thanks for your reply, but the issue is not regarding confirmed uplink. The node is sending unconfirmed uplinks every 15 seconds. The frame counter is incrementing correctly in the node, but the Chirpstack LNS is skipping some of the uplinks in between (this is visible in the attached image).
What might be the issue?
