I can send messages to my RAK7258 WinGate Edge Lite with the sendlora () function, and see them by mqtt in node red.
but i need to receive data back. is there a way or some routine example to receive a downlink from a RAK7258 WisGate Edge Lite to a Rak4630?
Hei @diegoatzin ,
You can send test downlinks via the built-in server:
You should be able to also do this via Node red, what sends the downlinks is the LoRa Server itself the gateway just forwards them. So, it would depend on what LoRa Server implementation you are using for the downlinks.
Regards Vladislav
